Toymods » Tech & Conversions » Front struts (again) - What's a few threads between friends?
Lucid
Toymods Club Secretary
Front struts (again) - What's a few threads between friends? Mon, 29 March 2004 09:16 Go to next message
This is just a quick question I'm asking for safety's sake.. I have recently acquired some new front shocks for the Corolla (inserts) and have also had to get a set of original strut housings as I previously had aftermarket units that were not rebuildable.
If you take a look at the two pictures below it might explain the reason for me asking the question:
The first is a picture of just the strut housing with the end-cap screwed all the way down. (The end cap was supplied with the new insert).
http://www.luc1d.net/images/thread1.jpg
The second picture is of the strut housing with the insert in, and the end cap screwed all the way down.
http://www.luc1d.net/images/thread2.jpg
Notice the fact that there is a decent 2 - 2.5 threads still exposed above the top of the strut housing?
What I mainly wanted to ask here is:
- Is this normal?
- Is this safe?
I've never actually seen the original struts before now, so I don't know what they would normally look like with the shock absorbers in, and I don't know if other people who've changed them over have come across the same thing.
Probably about 3/4 of the thread on the end-cap is actually screwed through inside, but I was still just a bit worried/curious as to whether it's safe to put in the car like this..
Any help guys??
[Updated on: Mon, 29 March 2004 09:18]
Re: Front struts (again) - What's a few threads between friends? Mon, 29 March 2004 09:34 Go to previous messageGo to next message
from memory its normal dude.... i seem to remember my celica struts being just like that and me having the same worries Smiley =
IRA11Y
Club Member
Re: Front struts (again) - What's a few threads between friends? Mon, 29 March 2004 09:52 Go to previous messageGo to next message
look on the bottom of the shocks, most will have a sacrificial stub that you can cut down to the right height, trim it down a little at a time or measure accurately what you need to remove and trim it till the cap is a down firmly, the cap will probhably be ok how it is but its best to fit it correctly if you can.
Re: Front struts (again) - What's a few threads between friends? Mon, 29 March 2004 09:58 Go to previous messageGo to next message
Its perfectly normal. All the TA22 struts I have seen have a few threads protruding the strut casing. It was also exactly the same when I purchased some new Boge inserts which came with new end caps.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Front struts (again) - What's a few threads between friends? Mon, 29 March 2004 10:30 Go to previous messageGo to next message
As Michael said, grind a bit off the bottom, there's usually some provision to do so, but just make sure you don't grind off too much, there's nothing worse than a shock that can rattle around inside the strut.
It took me ages to work out what that bloody noise was. Smile
Lucid
Re: Front struts (again) - What's a few threads between friends? Mon, 29 March 2004 11:43 Go to previous message
Thanks all Smile I at least feel a lot better about it now even if I leave it the way it is..
Am a bit hesitant to tackle the task of cutting down the stubs at the bottom. I really don't want to risk taking too much off, or getting the left and right at different lengths. I also don't have immediate access to the right equipment either. Confused
With a bit more time I might be able to cut them down in length properly, however I want to get the things in and aligned before Easter (ie. less than two weeks now!!). Only have a benchtop or angle grinder here at home and I'm not going to attempt it with either of those (far too hit & miss for my liking - especially if you've seen me weilding a grinder!).
If it will be OK, then it might have to do for now until I get a bit of time to pull them out and get them over to a friend's place where I'll have access to a lot more equipment! Very Happy
Thanks again!!
Previous Topic:putting boost gauges into air vents
Next Topic:O2 & Speed Sensor
Current Time: Fri Oct 9 08:20:23 UTC 2026
Total time taken to generate the page: 0.0049929618835449 seconds
