Toymods » Tech & Conversions » 1JZ-GTE musings
Esteban
Brisbane - Chapel Hill
icon6.gif  1JZ-GTE musings Mon, 29 March 2004 14:35 Go to next message
I recently had my first run-in with a 1JZ conversion ...
http://esteban.meridiantech.com.au/misc/toymods/10 0_1521.JPG
... '98 VVTi single turbo 1JZ-GTE into a VL (dont ask) ...
and I was surprised by the teensy size of the exhaust ports ! not to mention the exhaust manifold to the turbo. The stock exhause manifold even has welded in expansion joints (dont know if this is unusual) I assume the turbo is another CT26 incarnation? - non twin entry, but the manifold at least joins the 3 tp 6 cyls directly before the exhaust wheel. Sorry I didnt snap a pic, but the opportunity is still available for tomorrow-ish.
To me it seems this engine has heaps of potential, but is factory tailored for more sedate duties. Cant wait to unleash the beast in such a light car!
It's almost as if the std exhaust manifold is a factory restrictor (or perhaps it explains that meaty 380nm+something of low-down torque?) Hopefully we can get the bitch going in stock trim, im really keen to see how toyotas late model (well later than anything i usually play with) stock engines perform...
Any thoughts/experiences?
Re: 1JZ-GTE musings Mon, 29 March 2004 23:16 Go to previous messageGo to next message
Yes, all JZ engines have small exhaust ports and restrictive manifolds. The purpose of this is to keep exhaust gas velocity high, thus encouraging quick spool-up. That's the reason a 1JZ is amazingly torquey for a 2.5 litre engine.
And yes, there are plenty of gains to be had by opening up those ports and replacing the stock manifolding with something a bit bigger.
deesonet
Toowoomba
Re: 1JZ-GTE musings Tue, 30 March 2004 11:26 Go to previous messageGo to next message
Hey Esteban
I fitted a 1JZGTE into a VL two years ago and have almost completed a 1JZGTE VVTi into a Lexus IS200. Come up to Toowoomba some day if you want to have a look.
The VL was an awesome performer in full flight. You will have fun with it.
ChuckLandwehr
Re: 1JZ-GTE musings Tue, 30 March 2004 12:03 Go to previous message
Hi there Esteban, December last year finished fitting a VVTI 1JZ-GTE into an RA23 Celica. Initial dyno run without any modifications, and 10 psi boost saw, 170Kw@ wheels via W58 manual box.
Masses of FUN! FUN! FUN!
regards Chuck.
Previous Topic:Vibrations when under deceleration
Next Topic:AE86 conversion
Current Time: Sat Oct 24 01:37:33 UTC 2026
Total time taken to generate the page: 0.017252922058105 seconds
