Toymods » Tech & Conversions » oil pressure
kristian
oil pressure Sun, 18 August 2002 07:20 Go to next message
hi guys
I have a 4age bluetop in ae86, after changing oil with mobil 5w 50 and oil filter my oil pressure gauge has stoped working, or could it be that there is no pressure at all. thnks
GIN51E
Berowra-Sydney
Re: oil pressure Sun, 18 August 2002 07:24 Go to previous messageGo to next message
did u put the oil drain plug back in????
don't laugh i've seen it happen a few times Freak
double check the guage is connected properly as it may have been bumped or damaged while you were fiddling under the bonnet but the oil thickness shouldn't have any real effect on the oil preassure.
kristian
Re: oil pressure Sun, 18 August 2002 07:28 Go to previous messageGo to next message
everything is fine, temp is ok ive driven it a few times. put in a new seal with the oil plug. yes its prolly the wire... but i have no idea which it is, next to battery ? anyone describe in detail thnks
Re: oil pressure Sun, 18 August 2002 09:21 Go to previous messageGo to next message
The oil pressure sensor is the little round shinyish thingo screwed into the block a short way in front of the oil filter, with 1 wire going to it. It might be hidden behind an A/C pump or alternator though, depending which parts you've got on your 4AG.
kristian
Re: oil pressure Mon, 19 August 2002 10:45 Go to previous messageGo to next message
i dont have A/C pump, alternator is under the tvis. i saw a round bolt close to oil filter, guess this is where you plug in a oil pressure tester. dont know where this wire connects though
Grega
melbourne.victoria.austra...
Re: oil pressure Mon, 19 August 2002 10:58 Go to previous messageGo to next message
hmm. yes there is a bolt kinda thingo next to the oil filter to its left - then further toward the front of the engine is a sender looks like a little can - should have a terminal on it - a wire should go on there.
Re: oil pressure Mon, 19 August 2002 23:09 Go to previous messageGo to next message
yeah, that little bolt is nothing to do with it - look for the can further in front. If your oil pressure gauge did work, then you'll have the can with a wire on it
kristian
Re: oil pressure Tue, 20 August 2002 01:59 Go to previous message
wow finally fixed it. thnks for all the prompt replys, really appreciate it Smile. It actually looks like a bell that you find in kids bikes, i was looking for wire connectors, but you actually plug the wire to the tip of this dome... lmao ... Smile)
Previous Topic:Gear shift cable
Next Topic:Diff Questions
Current Time: Fri Nov 20 00:37:49 UTC 2026
Total time taken to generate the page: 0.0048439502716064 seconds
