Toymods » Tech & Conversions » 1ggte tacho!! any auto elections... sideshow??
CrAiGzEE
south of the big smoke
1ggte tacho!! any auto elections... sideshow?? Wed, 31 March 2004 02:47 Go to next message
im so damn angry!! grr just paid to get my 4 cylinder tacho recalibrated to 6, well that part is fine
but i used to have a cheap tacho that bounced when it hit say 4k and wouldnt read any higher, now this tacho is doing the same thing
i thought maybe the wires werent thick enuff to handle the current so i placed a thicker earth, thicker ignition and a thicker signal wire, still no difference
has anyone else had this problem? or know how to fix it??
currently im getting the signal from the ignitor ill get a pic
cheers guys
ddeane
PNG
Re: 1ggte tacho!! any auto elections... sideshow?? Wed, 31 March 2004 04:14 Go to previous messageGo to next message
Craig
Go into the gallery on this site. Look in the first TechDocs folder and click on the 1G ECU pdf. Go to the bottom of the connections that I have scanned to the last plug. Remember when you wired your car you had 3 computer plugs and 2 other plugs. One of these plugs primarily covered connections to the dash - pin number 22 is the feed to the taco. And no u don't need thicker wires as there is no current involved - u just nee the right wire. Give me a ring if you are having more trouble
CrAiGzEE
Re: 1ggte tacho!! any auto elections... sideshow?? Wed, 31 March 2004 05:54 Go to previous messageGo to next message
Craig YOU ARE THE MAN!
all done
thanks again
i might ring you reguarding a little problem i have later tho
Fattony
Re: 1ggte tacho!! any auto elections... sideshow?? Wed, 31 March 2004 07:22 Go to previous messageGo to next message
Hmmm just out of interest who did you get to recalibrate your tacho?
CrAiGzEE
Re: 1ggte tacho!! any auto elections... sideshow?? Wed, 31 March 2004 11:37 Go to previous messageGo to next message
the place is called humpreys instruments, they specialise in anything to do with instruments,
working sweet!!
ddeane
PNG
Re: 1ggte tacho!! any auto elections... sideshow?? Thu, 01 April 2004 02:06 Go to previous messageGo to next message
Gidday
I have one you can have $40 plus postage.
Craig
ae86drift
sydney.au
Re: 1ggte tacho!! any auto elections... sideshow?? Thu, 01 April 2004 13:54 Go to previous messageGo to next message
speaing of tachos
ill be getting a pivot tacho in a week or so, whats the go with installing it in an ae86?
i also have oil press and oil temp elec gauges ready to go in, does anyone know what to do? im a gauge noobie and ive no idea with electics
CrAiGzEE
Re: 1ggte tacho!! any auto elections... sideshow?? Fri, 02 April 2004 05:13 Go to previous messageGo to next message
its fairly simple, 4 wires generally
*dash lights
*ign
*earth
*tacho feed
with the oil pressure and temp will depend if they are mechanical or electrical
Bugman
Re: 1ggte tacho!! any auto elections... sideshow?? Fri, 02 April 2004 09:00 Go to previous messageGo to next message
so you got my blue atcho going now?
CrAiGzEE
Re: 1ggte tacho!! any auto elections... sideshow?? Fri, 02 April 2004 13:18 Go to previous messageGo to next message
sure do nigger!
celicamad
newcastle
Re: 1ggte tacho!! any auto elections... sideshow?? Sat, 03 April 2004 11:17 Go to previous messageGo to next message
sixworks sells a tach converter that will get factory tacho working fine . the Cressida stock tacho now works spot on with 1jzgte installed sixworks@optusnet.com.au
FKN16V
NSW, East Coast
Re: 1ggte tacho!! any auto elections... sideshow?? Sat, 03 April 2004 11:29 Go to previous messageGo to next message
celicamad wrote on Sat, 03 April 2004 21:17
I know someone who will need one of these soon, whats the price, are they easy to install.
Grant will do the wiring loom when im ready for it, would i have to wait or are they ready to go.
Steve
Grant
Newcastle, NSW, Australia
Re: 1ggte tacho!! any auto elections... sideshow?? Sun, 04 April 2004 21:53 Go to previous messageGo to next message
Steve,
Tacho boosters are $98 and very easy to install; only 4 wires.
What wiring loom and I doing?
CrAiGzEE
Re: 1ggte tacho!! any auto elections... sideshow?? Sun, 04 April 2004 23:24 Go to previous messageGo to next message
i dont think we are talking about the same thing here
i got my tacho converted so it reads that of a 6 cylinder not 4 cylinder, say if i was reving it to 4k it would show 6k cause of the extra 2 cylinders, i got that problem fixed
i believe grant tacho booster boost the tacho signal cause it has coil pack unlike the oginal cressy engine am i right?
Grant
Re: 1ggte tacho!! any auto elections... sideshow?? Sun, 04 April 2004 23:30 Go to previous messageGo to next message
Correct. The answer I gave was in response to FKN16V's question. I wasn't trying to hijack the thread.
CrAiGzEE
Re: 1ggte tacho!! any auto elections... sideshow?? Sun, 04 April 2004 23:45 Go to previous message
nar nar i know what u ment, my responce was in reguards to celicamads Smile
[Updated on: Sun, 04 April 2004 23:47]
Previous Topic:RT 132 brakes into ta22. What shocks? Spring perch?
Next Topic:SPECS: 2T-G OEM camshaft profiles
Current Time: Sun Oct 25 00:39:33 UTC 2026
Total time taken to generate the page: 0.0061318874359131 seconds
