Toymods » Tech & Conversions » 3sfe throttle body
Chas
3sfe throttle body Wed, 31 March 2004 03:05 Go to next message
I was wondering if someone can help me with some queries about the Camry 2 litre 3sfe throttle body:
does the auxilliary air valve (IAC) have a heat activated valve, or is the electric rotary valve used to do this function i.e is the coolant connection only for winter ice or to heat a bimetallic element ;
is there a TPS that can replace the switch module, so I can get a variable signal of throttle position;
the output from the auxiliary air valve goes to a pilot operated regulator on the opposite end of the plenum:- does the regulator restrict the air on vacuum to the pilot port or admit more air?
I would apprceiate any help here
Chas
Re: 3sfe throttle body Wed, 31 March 2004 05:06 Go to previous message
Ok you can ignore the query about the auxilliary air valve, I have worked that out.
I just need to find out about the regulator and TPS
[Updated on: Wed, 31 March 2004 05:07]
Previous Topic:NGK Spark Plugs
Next Topic:100kw 4age fuel delivery
Current Time: Wed Oct 28 06:11:31 UTC 2026
Total time taken to generate the page: 0.0071399211883545 seconds
