Toymods » Members Rides » ra40 megasquirted 18rg
RA40Celica
Hobart
  chris_rg@jabber.org
ra40 megasquirted 18rg Wed, 31 March 2004 03:51 Go to next message
Engine:
Megasquirt EFI
18RG
early 88210 head
later 18rgu cams, 88250 (not ideal)
9.7:1 compression pistons
points ignition running jaycar HEI ignitor (will be fully computerised eventually, maybe even coil per plug)
Fuel system:
Standard mech. lift pump
Custom Surge Tank
VL Commodore efi pump
commodore fuel filter
EFI Manifold etc:
18rgeu bits including plenum, throttle body, injectors, fuel rail, fuel regulator, etc
MAT (manifold air temp sensor) GM ait temp
CLT (coolant temp) early toyota sensor
unifilter air filter
commodore heated 4 wire oxygen sensor
Haltech TPS
throttle cable off something like ae92 corrolla
Cold air intake
Suspension:
aftermarket, low and stiff spring (unknown brand)
aftermarket shockers (unknown brand)
aftermarket swaybars front and back (unknown brand again)
Wheels:
14in x 7
large offset, haven't measured
195R14 60 tyres
[Updated on: Fri, 05 November 2004 01:25]
Evil_Foetus
Ballarat, Victoria
Re: ra40 megasquirted 18rg Wed, 31 March 2004 06:27 Go to previous messageGo to next message
thats a very very tough RA40 Very Happy
i like it. Evil or Very Mad
SetMeFree
Yagoona Sydney
Re: ra40 megasquirted 18rg Wed, 31 March 2004 06:36 Go to previous messageGo to next message
How cool!!! congratz on a nice ride Smile
RobST162
Re: ra40 megasquirted 18rg Wed, 31 March 2004 07:24 Go to previous messageGo to next message
nice mate
Simon
Sydney, Australia
Re: ra40 megasquirted 18rg Wed, 31 March 2004 09:17 Go to previous messageGo to next message
Nice car dude! Cool
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Wed, 31 March 2004 15:08 Go to previous messageGo to next message
thanks for the comments guys...
that post is little out of topic since it was copied from a post to another forum.. lol... i know, im lazy...
the car has the usual stuff like pedders suspension, i'm getting a LCD dash called megaview which will display parameters from the ecu such as air temp, coolant temp, and many others. I can also make changes to any confirguration of the ecu like that aswell. Smile
It was resprayed and engine rebuilt by previous owner a few years back and lived in garage until i bought it and registered it. some one before that owner did the suspension.
Damn, i really should get new oil pressure sender aswell... thats WAY over due.
other things which need fixing include the diff center and interior.
a good exhuast would probably help aswell.
Chris
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Wed, 31 March 2004 15:30 Go to previous messageGo to next message
a thread is going about megasquirt at
http://forums.toymods.org.au/index.php?t=msg&t h=32215&rid=572&S=d5fd8dc724436ad7dd7654b2 b56e1142&pl_view=&start=0#msg_284068
if anyone is intrested
Chris
rob_RA40
c'town, NSW
Re: ra40 megasquirted 18rg Thu, 01 April 2004 02:08 Go to previous messageGo to next message
what size wheels and tyres are they?
looks very nice man well done.
Lambolica
Northwestern Sydney
Re: ra40 megasquirted 18rg Thu, 01 April 2004 02:18 Go to previous messageGo to next message
What work has been done to the engine? Cams etc.?
Nice colour I likey.
what were the costs involved in installing the megasquirt ecu (ie sensors etc) I have an 18R-GEU that I'd like to have the megasquirt wired to for a dyno run.
any power figures (guesstamations)
Yep like that colour. Cool
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Thu, 01 April 2004 05:52 Go to previous messageGo to next message
I'm pretty sure the engine has stock internals. The previous owner did the rebuild, not sure what compression pistons he put it either. I dont feel like pulling it apart to find out lol. cams are 88250, head is 88210... not the best combination i know, but it goes ok. its got a set of average looking extractors, and a crap exhaust.
rob - the tyres are 195R14 60 profile ... the wheels are 7 inch wide i _think_ ...don't know what the offset it, but its pretty huge.
Chris
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Fri, 02 April 2004 13:14 Go to previous messageGo to next message
oh and costs...
Custom Surge Tank - $20 bucks for fittings
VL Commo efi pump - $60 from wrecked VL
commo fuel filter - $10 maybe, can't remember
fuel lines and clamps etc - $40 ???
plenum, throttle body, fuel rail, fuel regulator - all this for free!
MAT (manifold air temp sensor) from VL coolant temp - $17
CLT (coolant temp) early toyota sensor - free
unifilter air filter - $50
O2 sensor - $50 + $50 for fitting
Wiring and relays etc etc - $200
Megasquirt and megastim - $225
injectors - $50 thanks clancy
probably others a can't think of right now around the $700 total mark i think.
and a few tanks of fuel cruising around testing and tuning Smile
Chris
people100
Rocklea qld
Re: ra40 megasquirted 18rg Sat, 03 April 2004 05:43 Go to previous messageGo to next message
Would the megasquirt run aq turbo conversion. was it easy to hook up. Where did ya get it from and was it new when ya got it. Im toying with the idea myself.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Sat, 03 April 2004 06:25 Go to previous messageGo to next message
The megasquirt will run pretty much anything.
have you looked at the thread going in the Tech section about megasquirt, a lot of info in there.
I bought it as a kit, pcb and components, soldered it together.
It would be pretty much the same to setup as any other efi computer i'd imagine. I've only ever done this one though.
The megamanual can be found at www.megasquirt.info it is very comprehesive manaual. with sections for assembly, wiring, injectors, etc etc.
Chris
jukkaj
Finland/Hyvinkää
Re: ra40 megasquirted 18rg Sun, 31 October 2004 18:18 Go to previous messageGo to next message
Are the efi manifold originally 18 r-ge??
I have under construction megasquirt also to 18 r-gu
and turbo!! Car is toyota crown -65 rs-41
[Updated on: Sun, 31 October 2004 18:50]
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Sun, 31 October 2004 22:49 Go to previous messageGo to next message
yes the efi manifold is original for the 18rgeu.
excellent, there are a couple of people on these forums going the turbo road.
gearb0x
Re: ra40 megasquirted 18rg Thu, 04 November 2004 11:13 Go to previous messageGo to next message
i was wondering where you mounted the IAT sensor and the coolant sensor?
Im doing a similar conversion on a 2tg
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Thu, 04 November 2004 11:30 Go to previous messageGo to next message
coolant sensor is in the factory location in the thermostat housing for an 18rgeu.
and i mounted the airtemp sesnor in the air ducting just before teh throttle body.
Chris
cam_RA40
Launceston, Tasmania
haha, funny little head!
Re: ra40 megasquirted 18rg Fri, 05 November 2004 06:59 Go to previous messageGo to next message
hey chris, havn't heard from you for a while. It's cameron here, i used to drive the green ra40 in Hobart, i have an ae92 hatch now. You're car is looking tough as, sounds like you've done a good job with the mega squirt setup.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Fri, 05 November 2004 23:58 Go to previous messageGo to next message
yeh ive seen your posts about your imported car when you got it.
My car is going ok, it needs some serious thought into wheels and suspension, at the moment its a bit stiff for these tassie streets and a little crazy in the wet.
if i can get a job it will be:
-brake upgrade
-bushes
-springs
-shocks
-new cams for 18rg
at the moment i often go out to baskerville to watch some mates like jonny. one day i would be keen to get out there, at the moment can't afford the risk of breaking my daily driver car.
people100
Rocklea qld
Re: ra40 megasquirted 18rg Sat, 06 November 2004 11:48 Go to previous messageGo to next message
how much trouble did u have getting it running originally with the ms???? im gonna start mine on a 2s ecu and wiring first then hopefully swap to the ms and hope it runs
RA40Celica
Hobart
  chris_rg@jabber.org
Re: ra40 megasquirted 18rg Sat, 06 November 2004 23:36 Go to previous message
yeh,
i didn't have any trouble at all. Mine almost ran first kick, i just had to replace a couple of fouled plugs.
The only difference with your setup is the electonic ignition. becasue im running pionts with a jaycar ignitor.
Hopefully soon i will get an electonic setup going and i might beable to help you more.
good luck with it
Chris
Previous Topic:Spectre's RA28 (Interior Overhaul + Pics)
Next Topic:1JZ MX83 Cressida
Current Time: Fri Nov 20 09:00:24 UTC 2026
Total time taken to generate the page: 0.006688117980957 seconds
