Toymods » Tech & Conversions » ae86 problemS
45aken
NSW.south coast.Drifting
ae86 problemS Wed, 31 March 2004 12:28 Go to next message
here again, got some problems that i havent fixed yet and some questions;
my fuel gauge dosent work, but the idiot light does, does this mean there is a problem with the sender or the gauge in the cluster? (wire fell out etc)
my oil pressure/temp (forget) dosent work, no idea (havent tried to fix yet)
there is a semi loud ticking noise from my engine(4ac) bay, increases as the rpm does, im thinking exhaust leak maybe(sounds like a lawnmover Smile) , but it could be from the head. it started when i thrashed the hell out of it then realised there was no oil....was just gonna thrash it till it dies or i get a new motor(which everone comes first)
head light adjuster is stripped/screwed, how do i get to where it pushes the headlight up/down to fix it, or do i need a new headlight?
thanks all
Henn
Rosanna, Melb
Re: ae86 problemS Wed, 31 March 2004 13:00 Go to previous messageGo to next message
Fuel gauge and "idiot light" work off two different sensors. Check that there are no loose/broken wires first. Then you could try replacing the whole in-tank sender unit. There is a rubber access hole thing under the carpet in the hatch, keep digging until you get it out. Is an idea to drain the tank first.
On 4As oil pressure is fed off a single wire running from the sparkplug side of the block. Check this connection and trace it back.
Exhaust leak sounds like ticking, see if you can feel exhaust coming out round the manifold etc or take it to someone who knows the sound, they will be able to tell straight away. Or maybe your engine is just rooted.
Hen
shindeokure
melbourne
Re: ae86 problemS Thu, 01 April 2004 13:21 Go to previous messageGo to next message
most likely to be engine tappets or some shit like that which have come loose from too much revving.
Chrisso
London - for a while anyw...
Re: ae86 problemS Fri, 02 April 2004 02:28 Go to previous message
alternatively, with your gauge (assuming it's not the wiring), you can clean up the contact on the senders resister.
When you pull the unit out of the tank, there is a box at the top of the bent arm (the movable one). Pop this off with a screwdriver and you'll see the resistor (a spring like piece) and the contact. Clean these up and then make sure the contact is good. I bent the contact plate down a little bit to ensure better contact.
Mine's been working well for over 6 months now.
Previous Topic:Electrical query
Next Topic:different wheel offsets
Current Time: Fri Oct 30 03:45:40 UTC 2026
Total time taken to generate the page: 0.0038158893585205 seconds
