Toymods » Tech & Conversions » Running an engine without exhaust?
alex_ta22
Newcastle, Hunter Valley
Running an engine without exhaust? Thu, 01 April 2004 01:54 Go to next message
If u run your engine with no exhaust and extractors, just bare exhaust side, will this cause damage? in any way
Chas
Re: Running an engine without exhaust? Thu, 01 April 2004 02:28 Go to previous messageGo to next message
Your overlap won't match and you will probably run lean and hot. BMEP will drop. Expect burnt valves if you do it for extended periods.
Dodgy_Haro
Re: Running an engine without exhaust? Thu, 01 April 2004 02:59 Go to previous messageGo to next message
Chas wrote on Thu, 01 April 2004 12:28
Not to mention deaf ears unless you keep it below 3 kph ...
Re: Running an engine without exhaust? Thu, 01 April 2004 04:09 Go to previous messageGo to next message
Not to mention your engine bay will probably catch fire! Shocked
people100
Rocklea qld
Re: Running an engine without exhaust? Thu, 01 April 2004 05:30 Go to previous messageGo to next message
Burnt valves here u come.
alex_ta22
Re: Running an engine without exhaust? Thu, 01 April 2004 06:29 Go to previous messageGo to next message
how long running would it take to get burnt valves?
Rod83
Re: Running an engine without exhaust? Thu, 01 April 2004 07:31 Go to previous messageGo to next message
I would also like to know about this. I've got my primaries hooked up, but until I get it to an exhaust shop, I can't hook the rest up. I plan to get it towed there, but I need to get it onto the back of the truck first.
Chas
Re: Running an engine without exhaust? Thu, 01 April 2004 07:54 Go to previous messageGo to next message
Your primaries should create the required reversion, refaction and syphoning if they have been sized correctly. The collectors and secondary pipes are only a flue, although they too should create enough velocity to keep the gas hot and flowing.
alex_ta22
Re: Running an engine without exhaust? Thu, 01 April 2004 07:59 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 01 April 2004 08:01]
c2888
Re: Running an engine without exhaust? Thu, 01 April 2004 08:06 Go to previous messageGo to next message
Apart from sounding really cool and the most awesome noise your engine will ever make, you'll have bent exhaust valves when the cold(relative) air hits them and you get some neat thermal action.
dodgydan
sik sx
Sunshine Coast
Re: Running an engine without exhaust? Thu, 01 April 2004 12:34 Go to previous messageGo to next message
i dont know what could happen in this case sorry..but i was wandering, i have a crack in my exaust manifold it doesnt sound like its leaking or anything..but looks bad..is it screwed of what? i can get a pic if any one wants
Re: Running an engine without exhaust? Thu, 01 April 2004 12:43 Go to previous messageGo to next message
start engine
hold cloth over exhaust pipe, blocking the flow of exhaust gases.
if engine stalls, it's not leaking Smile (or not badly)
note: you can almost always hear exhaust leaks - they're *loud*
Chas
Re: Running an engine without exhaust? Thu, 01 April 2004 12:46 Go to previous messageGo to next message
Just be aware that if you have an oxy sensor for injection control, any air being sucked in will affect fueling. And yes although the manifold is running at 20ish psi the velocity of the air will create a -ve static pressure on the inside skin of the manifold. In the context of this thread you are panicking for little reason.
allencr
tallahassee FL usOFa
Re: Running an engine without exhaust? Thu, 01 April 2004 14:51 Go to previous message
i think that other then guessing, has anyone actually had burned or bent/warped exhaust valves from this cause??? i doubt it, other then chance & coincidence.
the corvair people used to plug their exhausts at shutdown because of these myths until they figured out that the valves were just crap(in that air cooled engine situation) to begin with.
i've been hearing this old wives tale for too long a time
Previous Topic:celica no go
Next Topic:SA63/RA65 radiators
Current Time: Fri Oct 30 16:50:07 UTC 2026
Total time taken to generate the page: 0.006878137588501 seconds
