Toymods » Tech & Conversions » Remote Oil Filter for 4AGE 20 Valve ??
jkvsnn
Remote Oil Filter for 4AGE 20 Valve ?? Thu, 01 April 2004 06:27 Go to next message
Hi all,
I need to 'shorten' the oil filter on my 20 Valve 4AGE to allow for some 2" custom extractors. My current extractor design is setup to make all 4 primaries the same length but unfortunately, they now run through the standard factory oil filter. Crying or Very Sad
I need to shorten the filter by about 50mm so was thinking of either installing a 90 degree filter adaptor, finding a shorter after market filter adaptor block, or going for a remote filter setup.
Does anyone have any simple ideas of how I could reduce the amount that the filter and stock adaptors 'stick out' from the engine block ? The factory filter blocks are quite long. Are there shorter after market ones available ?
Thanks,
Julian...
j_o_e_l_05
Gympie, Queensland
Re: Remote Oil Filter for 4AGE 20 Valve ?? Thu, 01 April 2004 11:10 Go to previous messageGo to next message
what oil filter do you use now? you could try a z386 they suit most toyota's and are really small(but obviously hold a smaller amount of oil), other than that try wholesale performance for a filter relocation kit. or a local hi-po engine rebiulder, (or engineer) can shorten the filter for you.
Re: Remote Oil Filter for 4AGE 20 Valve ?? Thu, 01 April 2004 12:25 Go to previous messageGo to next message
i thought the 20v's already had the remote oil filter thing happening...
feral4mr2
Bundaberg, Qld.
Re: Remote Oil Filter for 4AGE 20 Valve ?? Thu, 01 April 2004 13:14 Go to previous messageGo to next message
Freak the last 20 valve block i looked at had the same oil filter sandwhich plate set-up as a 4age 16 valve. i dont know if all 20 valves are the same though?.
you could do like the later 4agze engines and put the oil filter directly to the block. i have done this with my 4agte, i used the bolt from the oil filter sandwhich bit that the oil filter screwed onto.
[Updated on: Thu, 01 April 2004 13:15]
fatmr2
Re: Remote Oil Filter for 4AGE 20 Valve ?? Fri, 02 April 2004 06:21 Go to previous messageGo to next message
I just bought a remote oil filter kit with a cooler as well for my 4agte.
Got mine from earls. Good stuff Smile not too expensive either.
Get a lot of clearance as well. might be worth a look.
My 2 cents........
Re: Remote Oil Filter for 4AGE 20 Valve ?? Sun, 04 April 2004 02:34 Go to previous messageGo to next message
Always go the remote filter, because even if you can stuff a filter in there, you'll swear and curse every time you try and change the thing, especially if things are a bit warm Evil or Very Mad
AE86slut
Baulko Hillo
Re: Remote Oil Filter for 4AGE 20 Valve ?? Sun, 16 May 2004 23:56 Go to previous messageGo to next message
Sorry to dig this up guys, but can someone please confirm that it is definately not a problem to run the oil filter straight on the block? I also have the problem of extractors fouling on the filter, but have taken the bolt off the 4AC and put that in the 20V block and just screwed on the filter straight to the block. What does that extension that the filter normally screws onto do anyway? Is it for cooling?
Cheers.
Grega
melbourne.victoria.austra...
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 01:21 Go to previous messageGo to next message
normally the sandwich plate b/w the oil filter and the block had two outlets which then go to an oil cooler - not sure on the implications on running a 4AGE without an oil cooler, i figure slightly cooler oil = longer lasting engine.
AE86slut
Baulko Hillo
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 01:26 Go to previous messageGo to next message
Thanks Grega,
There are no outlets that I can see. all it appears to do is space the filter further from the block. I will be running an oil cooler in the future, but for now to get the engine running, I am assuming that screwing the filter straight to the block will not pose any problems regarding oil filtering/distribution. Is this correct?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 03:36 Go to previous messageGo to next message
Hey slut, how's it going mate??? Smile
I've been meaning to give you call.....
Yeah there's no problem running an oil filter straight off the block, that's how my rwd 4AGE always was. I'd be interested to see this spacer, is it finned or have any other note worthy features? Or is it just a plain block, with an o'ring one side & a machined mating surface the other?
AE86slut
Baulko Hillo
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 03:50 Go to previous messageGo to next message
'sup Perm.... I mean.... Worm....
It's hard to explain, but it doesn't have any fins or anything. It really just appears to be a spacer, as it has the hole through the middle, and elongated holes around the edge for the oil to run through. Apart from that, there's nothing that looks like it actually does anything.
The filter seems to mate up fine with the 4AC bolt/pipe thing with the block so I'm sure it will do until I get a remote filter/cooler set up.
And yeah, give me a call you swine! hehehe
pro_ke
adelaide
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 13:03 Go to previous messageGo to next message
my 2c - id just move it because i wouldnt want the oil filter that close to the exhaust (not for safety, jsut cos i dont like the idea of overheated oil)
parts to move it are not that expensive
$50 sandwich plate
$80 remote mount base
$100 lines and fittings
plus you have the added bonus if you use braided lines and earls/speedflow fittings that your engine bay will look all pretty
Grega
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 20:12 Go to previous messageGo to next message
agree with pro_ke - but its the braided line and speedflow fittings that cost a bomb...the straight speedflow fittings are ok its the curved ones at 30 odd bucks each which get me.
oh and pushlock hose, 25 per metre dash 8.
AE86slut
Baulko Hillo
Re: Remote Oil Filter for 4AGE 20 Valve ?? Mon, 17 May 2004 23:21 Go to previous message
Thanks for your help guys. I think I will run it straight on the block for now just to get the engine running and check if it's ok (before warranty runs out!) as it has an acceptable amount of room between the headers and filter. Then I'll get the remote set up done properly with braided lines etc before I take it for a right thrashing.
Cheers.
Previous Topic:2JZ-GE Wiring Pinouts
Next Topic:4th Gen Wheel Guard Rubbing
Current Time: Sat Nov 21 07:19:58 UTC 2026
Total time taken to generate the page: 0.037303924560547 seconds
