Toymods » Tech & Conversions » GZE O2 Sensor Wiring
takai
GZE O2 Sensor Wiring Thu, 01 April 2004 12:34 Go to next message
Alright, for the 4A-GZE i know that three of the wires are for heating etc etc, but which three are they. I need to use my non heated (single wire) O2 sensor in my GZE (4wire input) as the heated version i think is either dead or getting cooked by the excess heat + the heating coil and therefore spouting wrong values and sending my closed loop fuel consumption through the roof.
So does anyone have a pinout or done this conversion before?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: GZE O2 Sensor Wiring Thu, 01 April 2004 16:17 Go to previous messageGo to next message
I think it's only two wires for the heating, the other two are signal & ground.
What colour wires do you have to choose from? The last 4 wire sensor I hav (I think from an ra65?) was black & black for heat, then blue for signal & white for ground.
I worked it out with a multimeter, one probe on the body of the sensor & checked each wire for continuity with the other, & the white one came up a winner.
Which only left blue for signal.
Re: GZE O2 Sensor Wiring Fri, 02 April 2004 23:40 Go to previous message
the two heater wires are usually the same colour, and should have around 2-5ohms resistance at room temp. connect one to 12V and the other to a solid ground AWAY from ECU.
of the other two, one is signal to ECU, the other is the signal ground... the ground wire should go to near the ECU ground (for better signal) and the other one goes to ECU...
http://home.earthlink.net/~jcgebhart/o2sens.html
this help??? Wink (joel's right too Very Happy )
afaik, the grounds should be independant of the sensor body (at least for bosch and NTK aftermarket ones) the toyota OEM might be different tho
Previous Topic:Removing Overspray
Next Topic:Can I put a 4AGE onto a K50 box?
Current Time: Sat Oct 24 19:58:35 UTC 2026
Total time taken to generate the page: 0.0043079853057861 seconds
