Toymods » Tech & Conversions » stainless vs aluminium IC piping
stainless vs aluminium IC piping Thu, 01 April 2004 12:46 Go to next message
ok, I'm sure there's a reason, but why is almost all aftermarket intercooler piping stainless steel, not the (much) lighter aluminium?
I'm sure one reason is wank factor - stainless is much shinier than aluminium.
I assume aluminium is a bitch to work with, and would be hell expensive?
can anyone shed some light on this? 'cause if it's purely for wank factor, I'd happily go aluminium
takai
Re: stainless vs aluminium IC piping Thu, 01 April 2004 12:51 Go to previous messageGo to next message
Aluminum is the wank factor one.
The main reason in my experience is cost. Tig welding is much much more precise than Mig welding (i can mig, cant tig for the life of me) and getting aluminum bends etc is a lot more expensive.
clubagreenie
1st street on the right
Re: stainless vs aluminium IC piping Thu, 01 April 2004 13:01 Go to previous messageGo to next message
Go to the right place and you won't need to have your stainless welded. Just join it at the ends. Try mandrel bending alu into that sort of shape.
Of course you could try a heat gun. Laughing
Re: stainless vs aluminium IC piping Thu, 01 April 2004 13:03 Go to previous messageGo to next message
yeah, I figured it was the cost involved with alumin... I've heard how hard it is to weld aluminium, and ... well, I've mandrel and press bent things before, and cant imagine aluminium would be very nice to work with
clubagreenie
Re: stainless vs aluminium IC piping Thu, 01 April 2004 13:06 Go to previous messageGo to next message
There's a place out around riverstone that I had some stainless (6 inch) mandrel bent a few years ago but they could bend up to 3 meter lengths and include some radical shapes as well. If only I knew the applications for this back then.
takai
Re: stainless vs aluminium IC piping Thu, 01 April 2004 13:10 Go to previous messageGo to next message
YOu would want at least one rubber join in there between the intake/turbs and the intercooler. I have three per side, including the intake and intercooler joins.
Just for engine flex.
I'm guesing you dont remember the name of the place?
Re: stainless vs aluminium IC piping Thu, 01 April 2004 15:01 Go to previous messageGo to next message
stainless steel polishes better for wank factor.
stainless is easier to bend.
stainless has lower thermal conductivity and higher strength.
aluminium is much harder to bend and doesn't polish as well. also needs more work to keep it nice.
welding of alloy is not that hard IF you have to right machinery.
TIG is best for both, but you can MIG staino with argon shielding gas. MIGing alloy sucks tho.. realyl need TIG and experience.
alloy bends will be more expensive, due to difficulty of bending AND limited use...
fwiw, alloy may give a slight increase in heat lost, is lighter, but more exxy. it's my choice tho.
also fwiw, i've heard of ppl who have a CNC alloy mandrel bender..
doesn't www.CAPA.com have alloy bends?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: stainless vs aluminium IC piping Thu, 01 April 2004 16:06 Go to previous messageGo to next message
www.are.com.au also have alloy mandrel bends (and are very helpful, I highly recommend them), but I'm gonna be seeing a guy soon who's started/ing up a business mandrel bending alloy pipes for intercoolers in the Eastern Creek area. He used to work for qantas so he's bent up a few alloy pipes in his time.
I've spent a fair bit of time watching alloy pipe being bent up at work, & they certainly have some intricate shaped pipes. The amount of scrap they go through is incredible, they'll use 5 or 6 metres of test pipe just to set up the bender, and it all gets chucked out afterwards!
Pity they don't do anything larger than 2", but at least that'll do for my turbo to 'cooler piping. Evil or Very Mad
A CNC bender, now I'd like to see that! Smile
Re: stainless vs aluminium IC piping Thu, 01 April 2004 22:58 Go to previous messageGo to next message
FWIW I'd recommend TIG welded mild steel with HPC coating. A bit more expensive than stainless but insulates much better than stainless or aluminium.
Alainve
Newcastle NSW
Re: stainless vs aluminium IC piping Thu, 01 April 2004 23:59 Go to previous messageGo to next message
ive got a CNC bender at work its a regular press bender and only goes up to 1 1/2 inch Crying or Very Sad its really wierd to watch it going cos its so fast and precise and it does a full 6 meter length of copper piper in around 1 minute with around 7-8 bends. the only machine thats freakier is the robot arm welder now thats wierd
Special Ed
I wanna go Hawaiiiiii.......
Re: stainless vs aluminium IC piping Fri, 02 April 2004 05:29 Go to previous messageGo to next message
I am sure that GCG turbos can now source 1 piece multiple bend pipes in alloy and staino. custom made to your specs.
They can take a bent peice of wire that you give them and the machine (cnc bender ?) reproduces the bends IN ONE PIECE !
SeptemberSquallIndustries
Re: stainless vs aluminium IC piping Fri, 02 April 2004 06:42 Go to previous message
Hey http://www.capa.com/ goes to an orchestral society try http://www.capa.com.au/ cheers!
Previous Topic:What performance brake pads do you use?
Next Topic:mz21 mini spool
Current Time: Wed Oct 28 08:12:43 UTC 2026
Total time taken to generate the page: 0.0061221122741699 seconds
