Toymods » Tech & Conversions » RT118 Brake Upgrade, Stud Pattern Change and Diff.
Bitza
Country Victoria
RT118 Brake Upgrade, Stud Pattern Change and Diff. Thu, 01 April 2004 14:01 Go to next message
I've got a 1975 RT118 Corona Wagon as a project car and I hope someone can help with the following questions.
1 - Upgrading to 4 wheel discs.
I going use a booster off a later RT104/118 and Commodore mast cyl to start with since it has inbuilt proportioning valve.
What other brake components from other models will interchange to convert to 4 wheel discs.
2 - Has anyone converted an RT from 4 stud to 5 stud.
I had thought of possibly using Crown rotors and/or stubs, but I don't know anyone with these to compare measurements etc.
3 - Diff conversion, something stronger than the original.
As above, what model will or won't fit and what ratio's are there to choose from.
Craig
Bitza
Country Victoria
Re: RT118 Brake Upgrade, Stud Pattern Change and Diff. Sun, 04 April 2004 08:13 Go to previous messageGo to next message
Can't anyone help or am I asking too much !!!!
SeptemberSquallIndustries
Re: RT118 Brake Upgrade, Stud Pattern Change and Diff. Sun, 04 April 2004 08:18 Go to previous messageGo to next message
Why?
A lot of guys use Hilux rear ends to great effect in older Toyota applications but for your application some independent research may be required.
Bitza
Country Victoria
Re: RT118 Brake Upgrade, Stud Pattern Change and Diff. Sun, 04 April 2004 08:43 Go to previous messageGo to next message
SeptemberSquallIndustries wrote on Sun, 04 April 2004 18:18
Why?
2 - Why not ! Main reason is rim style/pattern choice and I thought of using Crown bits on the front if possible because they're Ford pattern.
3 - Time for the tap measure on rear track width by the sounds of it.
Craig
Re: RT118 Brake Upgrade, Stud Pattern Change and Diff. Sun, 04 April 2004 08:55 Go to previous messageGo to next message
Why not..? Well, is it the most important thing to you or is there other things more deserving of your money? Is there *nothing* you can find in 4x114.3 PCD you can use?
Bitza
Country Victoria
Re: RT118 Brake Upgrade, Stud Pattern Change and Diff. Mon, 05 April 2004 08:11 Go to previous message
SeptemberSquallIndustries wrote on Sun, 04 April 2004 18:55
Haven't come across any wheels in 4x114.3 that appeal, unlike in 5 stud, but I am picky with wheels.
I didn't think wanting to change stud pattern was any different to others changing engines etc, everyone to their own.
Craig
Previous Topic:throttle body
Next Topic:Alternator charge wire fuse?
Current Time: Wed Oct 28 06:21:52 UTC 2026
Total time taken to generate the page: 0.011920928955078 seconds
