Toymods » Tech & Conversions » Help my 4AG doesnt turn
SW20R
icon9.gif  Help my 4AG doesnt turn Thu, 01 April 2004 14:36 Go to next message
Driving on my way to the pub, revved to 5k in first gear up a slightly inclined hill.
power dies *engine check light comes on*
change to 2nd, nothing engines stopped.
nrma reckons the timing belt is shreaded.. but will check. i did a diagnostics on the spot and it gave me an error 12. 1 .05 second blink and 2 shorter blinks.
FKN16V
NSW, East Coast
Re: Help my 4AG doesnt turn Thu, 01 April 2004 23:49 Go to previous messageGo to next message
Its a bit difficult too say, what was the diagnosis code again.
I would think the motor would just die straight away if the timing belt broke.
Toobs
Re: Help my 4AG doesnt turn Fri, 02 April 2004 01:10 Go to previous messageGo to next message
Definately timing belt symptoms...
At least 4A belts aren't hard to change
SW20R
Re: Help my 4AG doesnt turn Fri, 02 April 2004 03:23 Go to previous messageGo to next message
yeah it was the belt damm fwd
Flem
cambo
Re: Help my 4AG doesnt turn Fri, 02 April 2004 12:17 Go to previous messageGo to next message
have u done the belt yet or u need help i havent done one in ages
0422948007 matt do u have tools? my top box & roll cab wont fit in my car.
SW20R
Re: Help my 4AG doesnt turn Sat, 03 April 2004 08:43 Go to previous messageGo to next message
done the belt but it still wont start. timing is set. dizzy might be weak as the power from the coil is strong but not from the dizzy to the sparkies..
any spare 100kw dizzy/rotors?
Re: Help my 4AG doesnt turn Sat, 03 April 2004 10:34 Go to previous messageGo to next message
put a bloody toymods sticker on your car... then maybe i might've stopped!
P.S. you bogan going to the Tav.... PFFT!
SW20R
Re: Help my 4AG doesnt turn Sat, 03 April 2004 10:55 Go to previous messageGo to next message
i do have a toymods sticker on my car Laughing
oh well thanks anyway
Re: Help my 4AG doesnt turn Sun, 04 April 2004 06:34 Go to previous messageGo to next message
are you ABSOLUTELY sure that you have the cams in the right position?? did you rotate motor to check the valves are going up and down at the right time?
did you rotate motor to verify that the dizzy rotor is in the correct position relative to the cams, AND the crank?
not too often that a "dizzy is weak", since all it does is distribute spark....
double check your mechanical before starting an electrical diagnosis Wink
didn't knock off any plugs?
SW20R
Re: Help my 4AG doesnt turn Sun, 04 April 2004 07:12 Go to previous messageGo to next message
yes im pretty sure my settings are -
cams
intake - 12 o clock (pin matches the alignment)
exhaust - nearest to 12 0 clock (pin matches the alignment)
crank set to 0 bdtc
findings -
coil is good its putting out. ignition leads arent putting out power. i have tried 2 batteries and from the cap Im not getting any power and yes the cap has been set too.
pistons 1 and 4 are at dtc (cams are set to pins, crank at 0) and can be felt with a screw driver that they are at the top.
[Updated on: Sun, 04 April 2004 07:14]
Re: Help my 4AG doesnt turn Sun, 04 April 2004 07:22 Go to previous messageGo to next message
no no, what i mean is..
"have you verified that your valves are opening and closing at the correct time"
that is CRUCIAL to the motor running, and cylinders firing.
aftyer you have mechanically verified that the valves are opening (looking at pins is not good enough Wink )
then MECHANICALLY VERIFY that the dizzy is in the correct position.
from the cap you are not getting power??? what exactly do you mean by that?
if the coil is putting out, then either the dizzy is not aligned correctly, the cams are not aligned correctly, or you've bent and broken the conductors in your leads...
it is most likely to be something mechanical, cam timing, dizzy timing, damage to leads, etc..
Re: Help my 4AG doesnt turn Sun, 04 April 2004 07:31 Go to previous messageGo to next message
as for igntion leads... they should be approximately 3K ohms per foot.
Why dont you read this....
http://www.toymods.org.au/cgi-bin/photo/index.cgi? mode=view&album=/TechDocs/4age_book
helped me.
Cyber-punk
Brisbane, QLD
Re: Help my 4AG doesnt turn Sun, 04 April 2004 09:21 Go to previous messageGo to next message
THE WITZL wrote on Sun, 04 April 2004 17:31
helped me.
damn, i didnt think leads had resistance that high...well not really high, but i would of thought it was alot lower than that
SW20R
Re: Help my 4AG doesnt turn Sun, 04 April 2004 12:54 Go to previous messageGo to next message
helped me.
thanks karl
i found out what it was.. haha i feel so stupid right now.. Laughing
I DID rotate the crank so its dtc and pistons were hitting the top BUT I didn't look for the cavity pin on the intake cam shaft under the oil cap to see if it was compression. doh Shocked
i assumed it was compression becuase turning the crank it got heavy so i assumed.. haha it should start tommorow morning when theres light.
Re: Help my 4AG doesnt turn Mon, 05 April 2004 00:56 Go to previous messageGo to next message
silly boy!!!!
SW20R
Re: Help my 4AG doesnt turn Mon, 05 April 2004 01:05 Go to previous message
ok now the bitch turns! Surprised
but its idling rough, sounds like the map sensor is unplugged (alittle rotor styling) and it stalls
ive tried the 4ag book but still no avail.
its hard to start needs throttle or else it will just crank any ideas?
Previous Topic:top mount cooler mr2
Next Topic:RT 132 brakes into ta22. What shocks? Spring perch?
Current Time: Sun Oct 25 12:49:38 UTC 2026
Total time taken to generate the page: 0.0058860778808594 seconds
