Toymods » Tech & Conversions » Beams
dar_sbb
Beams Fri, 02 April 2004 23:33 Go to next message
Those the beams head pit onto the st162 block?
Re: Beams Sat, 03 April 2004 00:12 Go to previous messageGo to next message
heh heh, a mate put his response thru babelfish, figuring that you used it also to word your post Wink. he came up with
Quote:
"probabilities are the rays of light, the head on its block ST162 more than probably fit, but to try have you each main difficulties in to find and if them, me to hope that you have a deep briefcase"
Re: Beams Sat, 03 April 2004 00:15 Go to previous messageGo to next message
and the jenglish conversion Wink
Quote:
It is, being the deep bill tray where chance is the beam where the head perhaps is agreeable to your ST162 block with many, either big problem and, there are times when the fact that one which I desire is found is tried.
Re: Beams Sat, 03 April 2004 00:16 Go to previous messageGo to next message
and the english version
Quote:
yes, chances are the beams head will fit onto your ST162 block, but more than likely, you'll have either major problems trying to find one, and if you do, I hope you have a deep wallet.
Re: Beams Sat, 03 April 2004 00:22 Go to previous messageGo to next message
Very Happy and the english-german-english-japanese-english version
Quote:
It is that, chance the beam where perhaps the head is pleasant in many your ST162 block, the problem where either one is large, with I who am said desire, but when trying a certain fact, it is the plate of the deep bill where it is.
dar_sbb
Re: Beams Sat, 03 April 2004 00:40 Go to previous messageGo to next message
hahaha... response(s) appreciated! Laughing
Re: Beams Sat, 03 April 2004 00:48 Go to previous messageGo to next message
no worries Wink
his point was that even if it could (with the VVT/VVTLi bits) the motors are pretty exxy and finding a head may be difficult...
the beams is different to normal 3SGE, as it has lighter parts (no, i am not sure which) so it is optimised for higher rpm... i don't think bolting a beams head to a normal 3SGE would result in beams outputs... unfortunately....
it's a pity the buggers are so exxy!!
CelicaRA45
nth ringwood, Victoria
Re: Beams Sat, 03 April 2004 05:01 Go to previous message
for what its worth it will bolt up ,but you cant run the vvti as the gen4and 5 have another oil gallery in the block to feed it not availible on gen 1 to 3 also pistons are flat top as the valves are standing up more the cam pulleys are 5mm apart to 25mm aprt gen 1to 3 also have oil squirters and a thiner rod and a stronger block as well and as toby said there are 2 versions single and dual you can set up either for rwd if yoy no what you are doing
Previous Topic:Race seats
Next Topic:Removing Overspray
Current Time: Thu Oct 22 14:03:52 UTC 2026
Total time taken to generate the page: 0.0048060417175293 seconds
