Toymods » Tech & Conversions » 18RG rebuild
Dood
18RG rebuild Sat, 03 April 2004 04:14 Go to next message
I am wondering if anyone has done a 18RG rebuild recently. I am wondering about the overall cost for the parts (barings, gaskets, seals) since we are going to be doing the work ourselves.
Thanks.
Mr DOHC
Re: 18RG rebuild Sat, 03 April 2004 07:29 Go to previous messageGo to next message
depending on the engineering shop where u get your gasket kit, they can charge u up to $300 for a kit, or as low as $170
bearings
main: $50
bigend: $50
rings: $50
machining
depends on what u need, if u need just a hone, then just the cost of a hone down at autobarn
full recondition of the head including setting the shims is about $400-500
if u need pistons then u r up for a bit, cause u cant get them new off the shelf, u r best getting a set of hi-comp ones off the for sale section here,
anything more, just ask
SeptemberSquallIndustries
Re: 18RG rebuild Sat, 03 April 2004 07:44 Go to previous messageGo to next message
Autobarn + machining cylinder block = ?
Mr DOHC
Re: 18RG rebuild Sat, 03 April 2004 07:49 Go to previous messageGo to next message
i meant get a hone from auto barn {the tool, not the actual work}
Dood
Re: 18RG rebuild Sat, 03 April 2004 08:03 Go to previous messageGo to next message
Thanks mate. See how it goes on the rebuild since at the moment im not to sure what is excactly wrong with it. A couple of the cyclinders are just giving zero compression so we beleave it is a head gasket or piston rings.
CelicaRA45
nth ringwood, Victoria
Re: 18RG rebuild Sun, 04 April 2004 09:30 Go to previous messageGo to next message
or the shim clearences are out of wack like zero thou under the bucket will give you no comp 2
CelicaRA45
Re: 18RG rebuild Sun, 04 April 2004 09:31 Go to previous messageGo to next message
i have a complete 18rg head gaskets sets and other gaskets as well
sik sx
Sunshine Coast
Re: 18RG rebuild Sun, 04 April 2004 11:29 Go to previous messageGo to next message
costed me 70 for rings
40 for conrod bearings
250 for head reweld and grind/shave and asll the valves redone
220 for full engine gasket kit
for honing i just used course sandpaper Razz
all oils and belts and some hoses 150
new sparkies..they were surposed to be like 27 each but i got cheap 4 dollar ones
and i had to buy a few tools like ring compressor and the head bolt thing for the tension wrench..its all up been about 900 with everything including having to buy the manual witch was 40
good luck man
bbaacchhyy
Re: 18RG rebuild Mon, 05 April 2004 02:51 Go to previous messageGo to next message
sik sx wrote on Sun, 04 April 2004 21:29
Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked
Mr DOHC
Re: 18RG rebuild Mon, 05 April 2004 07:19 Go to previous messageGo to next message
costed me for honing i just used course sandpaper Razz
for the sandpaper u need to be hurt Confused
and who said they have to be $27 ones, they are supposed to be BP6ES for like $2.50 ea
sik sx
Sunshine Coast
Re: 18RG rebuild Mon, 05 April 2004 12:00 Go to previous messageGo to next message
whats wrong with doing that?? its does the ob obviously Razz
and the dude told me in his computer it says is recomended the platinum sparkies witch were 27 each for my car..most st162 owners would probly know about it
Mr DOHC
Re: 18RG rebuild Tue, 06 April 2004 08:07 Go to previous message
sorry, i thought u meant an 18RG
Previous Topic:conversion places in brisbane
Next Topic:ae-86 help
Current Time: Fri Oct 30 07:54:29 UTC 2026
Total time taken to generate the page: 0.0051009654998779 seconds
