Toymods » Tech & Conversions » RA23 throttle linkage
GIN51E
Berowra-Sydney
RA23 throttle linkage Mon, 19 August 2002 10:50 Go to next message
my friend got himself a celica and its got the i'm guessing original throttle linkage where its metal mounts and linkages and so forth and his gas pedal has heaps of free play and just doesn't feel right anyone got ideas on how to fix this and make it nice and tight again? where are the adjustments?
i got no idea as my car uses a cable link up which is much more simple. Rolling
Grega
melbourne.victoria.austra...
Re: RA23 throttle linkage Mon, 19 August 2002 10:57 Go to previous messageGo to next message
its probably worn over years of use, so, two suggestions :
1. go to the wreckers - find one with less play (prolly cheaper)
2. take it apart and have all the connections *bronzed* then re-ground back to original size - thus eliminating the freeplay
GIN51E
Berowra-Sydney
Re: RA23 throttle linkage Mon, 19 August 2002 10:58 Go to previous messageGo to next message
so theres no adjustments on them?
Grega
Re: RA23 throttle linkage Mon, 19 August 2002 11:06 Go to previous messageGo to next message
there *sorta* is. there are sorta shafts with a thread on them which can be rotated BUT they have plastic connectors on the end of them which after 25-30 years will be brittle, so, when you go to remove them be very careful as they will prolly break..
RA28
Re: RA23 throttle linkage Mon, 19 August 2002 12:35 Go to previous messageGo to next message
You could do some kind of high-quality bending job...the long rod that goes across the back of the engine bay could take up a bit of slack with a stregically placed kink.
The best thing would be to bite the bullit and go to a cable setup. KE70 throttle cables are nice and long. I unscrewed one of the ball-joint connectors from the linkage setup and then melted the led slug off the end of the cable (that goes into the firewall) and then heat the lead up and feed it into the ball-joint connector thingy (through the hole where it screwed onto the rods). Then you can just snap it onto the accelerator pedal like the linkages used to!
Tim.
tanman
Re: RA23 throttle linkage Tue, 20 August 2002 11:10 Go to previous message
By new bushes or turn some up on a lathe.
Previous Topic:4a-c weird miss help
Next Topic:engine conversion for a ae86
Current Time: Thu Nov 19 21:17:04 UTC 2026
Total time taken to generate the page: 0.0041041374206543 seconds
