Toymods » Tech & Conversions » heat resistance of radiator rubber
heat resistance of radiator rubber Sun, 04 April 2004 13:27 Go to next message
alrighty, I popped by clark rubber to pick up some rubber to fill in the gaps around my thermo fan shroud... I wanted 100+ degree stuff, but they only stocked 90+ and 70+.
I needed 6mm thick (it's a farily large gap, so the rubber cant be too flexible) and the 90+ was only available in 3mm, so I went the 70+
I'm wondering if this will survive being between my thermos and the radiator. 1jz runs at around 90 degrees, so I'm a little nervous.
Re: heat resistance of radiator rubber Sun, 04 April 2004 13:47 Go to previous messageGo to next message
90+ will only be around top tank and upper part of rad?
by the time you've baked it stiff&brittle (from being over-heated) other things will need replacing? it's not like it'll suddenly melt and flame up Smile
Re: heat resistance of radiator rubber Sun, 04 April 2004 13:49 Go to previous message
well, the top bit is waht needs the most rubber Razz
Previous Topic:How do i read boost
Next Topic:oil catch can and oil breather tank
Current Time: Sat Oct 24 14:45:40 UTC 2026
Total time taken to generate the page: 0.005791187286377 seconds
