Toymods » Tech & Conversions » Diff oil cooler
Diff oil cooler Mon, 05 April 2004 04:59 Go to next message
I'm toying with the idea of installing an oil cooler on my Supra to increase the longevity of the diff. Does anyone have any experience with this? How would one go about installing such a system on a diff not originally designed for it?
Stenno
Re: Diff oil cooler Mon, 05 April 2004 05:27 Go to previous messageGo to next message
For a street car, why bother, but if you must Smile
FYI European delivered JZA80's had a diff cooler - probably a must considering the amount of high speed driving that is obtainable in Europe (mmmm autobarns).
Too easy - Pickup point (diff drain hole) and a feed point (filler hole), plus the other bits, pump cooler and lines.
[Updated on: Mon, 05 April 2004 05:27]
Drift pig
Yea its pretty straight forward. You get a fitting that goes into the drain plug of the diff. Then run a line from there to one side of the diff cooler then a line from the other side of the diff cooler that runs back into the filler hole of the diff.
Now the choice is up to you where you mount your pump. You can mount the pump so that it draws directly from the drain port and pushes through the rest of the system. Or you can have the pump draw through the entire system and dump back into the filler plug hole.
Both ways work but the second is a little more practicle.
And yes they do work well and keep the temps down. I have seen setups that have a themostat switch in them so the pump turns on during hard driving.
Which of course is always. Smile
Cheers Steve.
Re: Diff oil cooler Mon, 05 April 2004 06:11 Go to previous messageGo to next message
Cool, that's pretty much what I had in mind. The reason I'm considering this is because I know my diff gets very hot; after hard driving I get a fair amount of oil coming out of the breather. This is just driving it on the street, so imagine what will happen when I take it out on the track!
Rigging up a small cooler and oil lines is easy enough, but what about the pump? I imagine a special pump would be required, any ideas?
gabe
Re: Diff oil cooler Mon, 05 April 2004 06:24 Go to previous messageGo to next message
I am in the proccess of fitting an oil cooler to my diff and one to my transmission also.
The only pumps I have been able to find so far have been a Tildon unit ex USA, and also CAPA do one for their supercharger kits. Both are suitable for this application.
Gabe
Re: Diff oil cooler Mon, 05 April 2004 08:11 Go to previous messageGo to next message
Just get some fins welded onto the center of the diff housing. This seems to be the trick on a few dozen Escort rally cars I've seen over the last few weeks.
Re: Diff oil cooler Mon, 05 April 2004 08:39 Go to previous messageGo to next message
for pumps.. there is some BMW oil pump...
there is also the Mocal and Weldon pumps, actually designed for this
http://www.thinkauto.com/oilpumps.htm
http://www.weldonracing.com/pump4.htm
biased99
Re: Diff oil cooler Mon, 05 April 2004 08:55 Go to previous messageGo to next message
Norbie wrote on Mon, 05 April 2004 16:11
When I take my car on the track, the diff is required to work <euphemism> fairly hard </euphemism>. At the end of several sessions, it can leak a small amount of oil (ie. a drop or two), and so I imagine it's getting quite hot (and expanding the joining surfaces just "that much"), as it never does this in "normal" driving...
Given what you're putting through an F-series diff, it's reasonable to assume that it is also working hard...My point? Just that (in my never-ending quest to run things as cool as possible), I was also thinking about going this route...If I can get a diff-cooler fitted, and an engine-oil cooler, I'll just about have it done! Smile
I wonder if anyone makes a complete "kit" for this purpose? (ie. cooler, lines, and pump... *shrugs*)
IRA11Y
Club Member
Re: Diff oil cooler Mon, 05 April 2004 10:09 Go to previous messageGo to next message
TRD do a diff cooler kit for the AE86 which should fit the same way. Ive been looking at adapting the P/S pump from and SW11 but i cant find a pump ( except for $2K at trade brand new from toyota) to use for a trial.
CLG
Perth, Western Australia
Re: Diff oil cooler Mon, 05 April 2004 13:56 Go to previous messageGo to next message
Wouldn't a P/S pump push to fast to be truely effective? I'd personally be heading towards the Mocal range, and would have the pump pushing, over pulling in any setup.
Re: Diff oil cooler Tue, 06 April 2004 00:20 Go to previous messageGo to next message
Thanks for the info guys, all very useful! Smile
I'm also thinking about doing a similar thing for the transmission (I think I've proven transmissions get a pretty hard life in my car), but my plan is to install a temperature gauge first to see if it's getting hot enough to warrant a cooler. I'll keep you all posted.
KING_22
Oakleigh, Melbourne
Re: Diff oil cooler Tue, 06 April 2004 07:39 Go to previous messageGo to next message
i think u'll find that anything that can be cooled is whorth while doing Very Happy
kingmick
Banned by his request
moved to tamworth
Re: Diff oil cooler Tue, 06 April 2004 10:46 Go to previous messageGo to next message
vdo do a pump which most of the v8 supercars use. ive sold a few to them but they are around the $380 mark from memory. they are small so fit anywere.cooler isnt really needed for the street.
mick
Southo
Re: Diff oil cooler Tue, 06 April 2004 11:04 Go to previous messageGo to next message
Aussie R32 GTR's had a Rear Diff Cooler, I think that maybe the R33 V spec models had the same.
http://www.pbase.com/image/24874852.jpg
I saw one exactly like this at a wreckers for $350 complete
(Pump, core, hoses, mounting bracket)
SupraPete
Re: Diff oil cooler Wed, 07 April 2004 01:51 Go to previous messageGo to next message
Cool1 wrote on Mon, 05 April 2004 18:11
Yeah I agree this would be a good start. On my MA70 LSD its got some fins in it already, so this should be a bonus on a diff that doesn't have any already.
I'd also like to hook up a transmission cooler for mine. I've still got the stock MA70 (auto) cooler ready to go.
kingmick
moved to tamworth
Re: Diff oil cooler Wed, 07 April 2004 03:55 Go to previous messageGo to next message
i suppose i should have added!even racing you only need a diff cooler for endurance work. sport sedan dont use them because they only do 12 to 13 laps etc which is about 40-60km. most top ten cars have around the 650hp mark with 580-620 fp of torque. they dont need coolers same as a road car. diffs either a 9inch or hewland do it easy 40-60km so its the same with street cars as your not going to do more than 200km at hi speed{not telling were}. money better spent on good diff oil,decent breather and good bearings and gears.ive split a 9inch pumkin in half with power but never overheated a non endurace race car diff.
cooler wise a good endurance car will have an oil,fuel,gearbox,diff and power steering cooler(mainly only on tight tracks).
mick
p.s ive done from goondawini to dalby (230km} in 1 hour 10min
with a ae93 with a c52 box so i dont think you need one unless you have cash to burn.
._T_.
Re: Diff oil cooler Wed, 07 April 2004 04:20 Go to previous messageGo to next message
i know people hasve sucessfully used diesel fuel pumps as gearbox/diff oil pumps.
gtr oil pums setup is over $2k from nissan - and waso nly fitted to the aussie delivered r32's. no others got them
T
IRA11Y
Club Member
Re: Diff oil cooler Wed, 07 April 2004 06:15 Go to previous messageGo to next message
personally i wouldnt do it for the street or for occasional trips to wakefield etc.. but for off road applications they are pretty much a must on older diffs due to the torque application increasing the heat during wheelspin. Thats the only reason ive looked at it so far.. but youll see a lot of the guys running T series diffs in rally dont use them, but change the diff oil every meet.
ae86trueno
Re: Diff oil cooler Wed, 07 April 2004 06:24 Go to previous messageGo to next message
And change gearbox oil after every 2nd rally is a must, at some $15 a litre for gearbox and diff oil, its an expensive exercise but its worth the insurance. I know i cant afford $2500 for a new gearbox gearset or diff Sad
Ben
AE86 Trueno 4AGE
V8_MA61
Re: Diff oil cooler Tue, 08 June 2004 10:59 Go to previous messageGo to next message
Jeremy did you look at this any further to install in the new supra? Im looking at doing it also....
The skyline things looks like an idea? Let me know how you go...i'm looking into it as well.
also does anyone else know what other cars these came out in?
Blake
[Updated on: Tue, 08 June 2004 11:08]
V8_MA61
Re: Diff oil cooler Tue, 08 June 2004 11:19 Go to previous messageGo to next message
an idea, it must be possible to use the drain and fill holes in the ma61 diff for the return and feed lines for the cooler?
Re: Diff oil cooler Tue, 08 June 2004 12:07 Go to previous messageGo to next message
Nah, this plan has gone on the backburner for a while, I'm busy with other stuff (eg pulling a pair of Supras apart). I do intend to pursue it again when I get the time though!
V8_MA61
Re: Diff oil cooler Tue, 08 June 2004 12:09 Go to previous messageGo to next message
ill tell you how i go mate...maybe we can share plans of attack Smile
No idea what pump i should look for?
Re: Diff oil cooler Tue, 08 June 2004 12:19 Go to previous messageGo to next message
There's actually a pump for this purpose in the Goss catalogue, I'd imagine you'd be able to order it through any auto parts place. Not sure on the price, I'd imagine several hundren bucks. Only thing is, I haven't noticed anybody mention fitting a filter yet! Shocked
V8_MA61
Re: Diff oil cooler Tue, 08 June 2004 12:30 Go to previous messageGo to next message
i think this would be very difficult...
Youd need a valve so there is always the right amount of oil in the diff, not too much just being tossed around...
a lot more than meets the eye i suspect.
I guess ghowever i need it if i want to use the lsd wen i want to race the car...
Blake
82MKII
Re: Diff oil cooler Sun, 14 November 2004 13:53 Go to previous messageGo to next message
Hey Norbie,
is your truetrak still running hot, or was it just a bit of running in?
I finally got mine in over the weekend, and after 20 minutes on the highway the fins were quite hot (could only just hold my hand on them). I'm not losing any fluid though.
Anyone else recently installed a truetrak? Luke?
Anyone running a stock F series LSD care to take their car for a run & then feel the diff?
Peter
Re: Diff oil cooler Mon, 15 November 2004 00:26 Go to previous messageGo to next message
Any diff will get hot to the touch after a drive, that's normal. Boiling fluid on the other hand is not normal!
ZZT231
melbourne.vic.au
Re: Diff oil cooler Mon, 15 November 2004 00:33 Go to previous messageGo to next message
The Truetrac diff temp feels normal compared to stock in the MA61 after doing 100km drive. What Diff oil you are using?
Re: Diff oil cooler Mon, 15 November 2004 00:49 Go to previous messageGo to next message
Yes mine feels "normal" as well after a 100km drive, but 100km through the mountains at mostly WOT = boiling fluid. Something to do with 305rwhp I guess.
82MKII
Re: Diff oil cooler Mon, 15 November 2004 05:04 Go to previous messageGo to next message
Thanks guys - nothing much to worry about then.
I'm using redline 75W90 synthetic, so it should be running as cool as possible.
This morning it looks like it has developed an axle shaft seal leak - so it's back to the diff shop Mad
Peter
Sam_Q
S.E suberbs, Vic
Re: Diff oil cooler Tue, 16 November 2004 22:22 Go to previous message
wouldnt it be possible to just setup an oil coiler that comes off the entre/exit that used natural convection? as in the oil comes out the top cools down and sinks to the bottom? I know you would have to put a bit more oil in than normal for this but a fitting could be put on the back of the diff instead I guess. But again I guess it coems to it being worth the bother.
Previous Topic:Getting power out of a 4AGE
Next Topic:removing shocks
Current Time: Mon Nov 2 00:14:25 UTC 2026
Total time taken to generate the page: 0.015541076660156 seconds
