Toymods » Tech & Conversions » W58 gearbox ratios
drummerboy
W58 gearbox ratios Mon, 05 April 2004 17:09 Go to next message
Hey Dudes.
I have a mk3 Supra with a w58 gearbox. In 5th gear at 110 kph I'm doing 3200 rpm. I have no idea why Toyota would make a GT car with such petrol guzzling rpm's at cruising speed. Anyway, I want to drop the revs down to around 2500 rpm. Any ideas on if this can be done, correct ratios and availability of gearing?
Re: W58 gearbox ratios Mon, 05 April 2004 22:10 Go to previous messageGo to next message
Use a diff with 28% taller gearing.
What is your diff ratio? Should be on the build plate.
ra23celica
Re: W58 gearbox ratios Mon, 05 April 2004 23:37 Go to previous messageGo to next message
I'm surprised by this because the W58 g/box already has a more highly over-driven 5th gear in compariosn with the W57, 0.86 to 0.78, just for that reason you have given. I suspect a diff ratio change here.
Mitch.
Re: W58 gearbox ratios Tue, 06 April 2004 00:11 Go to previous messageGo to next message
NA MA70's had diff ratios as low as 4.3:1, which could definitely explain this situation. Is your Supra a local or JDM model?
dispatcher
Malaysia,Kuala Lumpur
Re: W58 gearbox ratios Tue, 06 April 2004 10:47 Go to previous messageGo to next message
Yes pleaaasseeee...i'd like to know too, i'm in the midst of changing my finals to 4.3 ish or 4.5 ish....
any input greatly appreciated.
KOFFEE-BLACK
Re: W58 gearbox ratios Tue, 06 April 2004 23:39 Go to previous messageGo to next message
On this subject, I have a JZA80 W58, with the Altezza LSD, I think the Ratio is 4.11, originally hooked up to the IS200 6 Speed, will this effect gearing, making it better or worse? And also the speedo, will it be out?
Cheers!!
Re: W58 gearbox ratios Wed, 07 April 2004 01:10 Go to previous messageGo to next message
NA JZA80's came with a 4.0:1 diff ratio, so your gearbox should work well with a 4.1:1 ratio. Speedo will probably be slightly affected, but this depends on the tyre diameter as well as the final drive ratio.
KOFFEE-BLACK
Re: W58 gearbox ratios Wed, 07 April 2004 02:24 Go to previous message
Sweet!
Previous Topic:Clutch Master Cylinder Issues - WHY!!
Next Topic:Camry Woes
Current Time: Wed Nov 18 15:44:13 UTC 2026
Total time taken to generate the page: 0.005051851272583 seconds
