Toymods » Tech & Conversions » brake question for corolla ae92
CrAiGzEE
south of the big smoke
brake question for corolla ae92 Mon, 19 August 2002 13:41 Go to next message
well my standard rear drums arent quiet doing the job i wanna upgrade to disks
*will i have to upgrade my booaster/master cylinder?
*what will bolt straight up?
*will the 101 front cut brakes bolt straight on
im not worrying about front atm as im aiming to have my front cut by the end of the year!
Johnny
Sydney, OZ
Re: brake question for corolla ae92 Tue, 20 August 2002 10:50 Go to previous messageGo to next message
Craig,
Best bet for your rear would be AE92 GTI or SX rears, which you need the calipers and the rear carriers. Also with the fronts, you'll need the steering knuckles and calipers for an AE101 and all will bolt in no fuss. Your master cylinder will be alright.
CrAiGzEE
Re: brake question for corolla ae92 Tue, 20 August 2002 10:55 Go to previous messageGo to next message
thanks mate
answered everything cheers
a mate was saying to get the 4agze engineered i would need to get the booaster bored out
do i have to do that
ae102_3sgte
Canada
Re: brake question for corolla ae92 Tue, 20 August 2002 10:58 Go to previous messageGo to next message
AE 92 and AE101 have different rear control arm mounts on the knuckles. Definately not bolt in.
As above, stick with AE 92 stuff!
(knuckles = carriers)
Johnny
Sydney, OZ
Re: brake question for corolla ae92 Wed, 21 August 2002 07:39 Go to previous messageGo to next message
Quote:
AE92 and AE101 have different rear control arm mounts on the knuckles. Definately not bolt in.
Do people on this forum have trouble reading??
REARS=AE92 GTI OR SX
FRONT= AE10# will bolt up
questions answered!
If you want to be real serious I can make you these...
http://members.ozemail.com.au/~johnek/fbrake.jpg with twin spot rears.... Those are AE92 front Knuckles on a AE102!!
Price depends on the caliper you want to use.
Re: brake question for corolla ae92 Wed, 21 August 2002 07:43 Go to previous messageGo to next message
Johnny, they're pretty serious Nod ....what calipers are they?
Johnny
Sydney, OZ
Re: brake question for corolla ae92 Wed, 21 August 2002 07:44 Go to previous messageGo to next message
Craig,
Boring out the booster is crap, could be worn and need a service, on that brake conversion above I've used the standard brake booster for the car, and all works well at 200kph!
Johnny
Sydney, OZ
Re: brake question for corolla ae92 Wed, 21 August 2002 07:57 Go to previous messageGo to next message
R32 GTR's, got them cheaper than the RX7's. Got to keep in mind I was on a budget Eye Spin ....
AP or Brembo = $15,000 Shocked
or
GTR or RX7 = $5,000 Rolling
This is for a whole lot of other work as well Wink
Rolla Boy
Club Member
Sydney, NSW
Re: brake question for corolla ae92 Wed, 21 August 2002 08:29 Go to previous messageGo to next message
I want some DBA longlife slotted discs... They are for a standard SX so I don't know if I want to go any bigger... Any comments???
CrAiGzEE
Re: brake question for corolla ae92 Wed, 21 August 2002 12:09 Go to previous messageGo to next message
johnny are they the slotted 20v brakes off a levin
how much am i looking at for a set of those brakes?
CrAiGzEE
Re: brake question for corolla ae92 Wed, 21 August 2002 12:11 Go to previous messageGo to next message
sorry was just reading again i would probably use sx callipers would they be any good
how much if i supply u with the calipers and how much without
ae102_3sgte
Canada
Re: brake question for corolla ae92 Thu, 22 August 2002 00:38 Go to previous messageGo to next message
questions answered!
end quote.
I am not challenging you.
I was explaining the difference in the rear knuckles between the two models (ie. why it will not fit). Personally I like to know why, not just yes or no.
I do not understand your bitterness.
Leighp
NY
Re: brake question for corolla ae92 Thu, 22 August 2002 00:42 Go to previous messageGo to next message
what size wheel is over those tasty 4 spotters?? was it a hard conversion??
Johnny
Sydney, OZ
Re: brake question for corolla ae92 Thu, 22 August 2002 11:53 Go to previous message
Ok,
The conversion consists of the following componets-
Front: Landcrusier DBA slotted Discs Bolted to a custom hat, Nissan GTR Calipers, the mounting for the factory calipers on the knuckle are cut off and a new machined mount is welded on. The welding is has to be done by a pro, as any weakness = no brakes!
Rear: DBA AE102 slotted fronts, with the hat machined off to suit custom hat. GTR Calipers, mounted using a new bracket which bolts directly to the existing mounts.
I run a H/Brake and bais valves as this is on a competition Rally car, but engineering is still necessary.
Sure on the rear, the 101 would be the better choice for the front, larger diameter
Sorry bad day in the office... I think the difference between the two models is cost. There's alot more work involve in producing the AE9# setup in the rear than the 10#, as for strength, the AE9# looks more robust for the abuse I give, but in the end ther do the same job.
There 16" which I run on Tarmac events. On dirt events, I use a 15" wheel and a 12mm wheel spacer just to clear the caliper and the rim.
Previous Topic:Fuel Pump Help!
Next Topic:timing stuff on 18-RC
Current Time: Wed Oct 21 09:01:11 UTC 2026
Total time taken to generate the page: 0.028137922286987 seconds
