Toymods » Tech & Conversions » Spongy brakes
dar_sbb
Spongy brakes Tue, 06 April 2004 11:47 Go to next message
i got a st162 and the brakes are spongy...
new master cyclinder seals have been put...
i also get brake fade quite quickly...
ne help would be appreciated
Jayem
Finland
Re: Spongy brakes Tue, 06 April 2004 12:18 Go to previous messageGo to next message
Stamp the brake pedal few times, if pedal rises after every kick you have air in the system. Bleed it.
If pedal stay in the same level after every stamp and is still spongy. Replace brake-hoses.
toof
Re: Spongy brakes Wed, 07 April 2004 07:44 Go to previous messageGo to next message
first thing, bleed the brakes out make sure there arnt any air bubbles in the lines. whilst your at it flush it though and replace all the fluid. check your pads whilst your at it.
after that consider replacing piston seals, brake lines etc.
keeping in mind that it isnt a bad idea to bleed your brakes regularly esp after a hard run if you do get a bit of fade (fluid fade not pad fade) once the brake fluid has boiled once its boiling teperature is severly reduced casuing it to boil more eaisly later on.
dar_sbb
Re: Spongy brakes Thu, 08 April 2004 00:28 Go to previous message
bleed brakes - Done many times... same result
Pads - got heaps left
only the brake lines have small cracks... changing them 2day
Previous Topic:Yankee Newbie with GA70 1g-gte Supra questions
Next Topic:where to find lsd
Current Time: Mon Oct 19 17:49:55 UTC 2026
Total time taken to generate the page: 0.085705041885376 seconds
