Toymods » Tech & Conversions » fwd gearbox problem - ae82
ae824age
fwd gearbox problem - ae82 Wed, 07 April 2004 05:02 Go to next message
I have just installed a new 100kw 4age into my ae82. Whilst the engine was out i chnaged the clutch over as it was fairly worn.
We started the car today and it runs wicked, but when i went to take for test drive i couldnt get it into gear Crying or Very Sad
Is there some sort of adjustment that can be done?
Does anyone know what this could possibly be??
Any help would be greatly appreciated
Chris Very Happy
kingmick
Banned by his request
moved to tamworth
Re: fwd gearbox problem - ae82 Wed, 07 April 2004 05:28 Go to previous messageGo to next message
did you undo the pipe going to the slave ?if so you need to bleed it,only thing it can be unless you changed to diffrent clutch or flywheel.
mick
ae824age
Re: fwd gearbox problem - ae82 Wed, 07 April 2004 06:13 Go to previous messageGo to next message
Cheers for the reply, i will bleed the clutch and see how i go Razz
FKN16V
NSW, East Coast
Re: fwd gearbox problem - ae82 Wed, 07 April 2004 06:40 Go to previous messageGo to next message
You did put the release bearing back in didnt you?
ae824age
Re: fwd gearbox problem - ae82 Wed, 07 April 2004 06:59 Go to previous messageGo to next message
I hope so .. as a friend helped me do it...i'll have to ask him
HighRolla
Re: fwd gearbox problem - ae82 Wed, 07 April 2004 08:48 Go to previous messageGo to next message
Bleed for sure. Get someone to look under bonnet will you push clutch to see if slave is pushing clutch lever. If air in line you will see it only move a fraction until you get rid of the air it starts moving more and more.
Clutch will also take up at different spot now so you may need to adjust master cylinder piston length near the pedal box. This is a must anyway whenever you replace clutch. Just undo locknut and rotate shaft from master cylinder to clutch pedal.
New clutch will be thicker so should contact earlier so you should probably have to lengthen the distance..can't think at moment but sure you can figure it out.
Hope it's something that simple Smile
[Updated on: Wed, 07 April 2004 08:56]
ae824age
Re: fwd gearbox problem - ae82 Wed, 07 April 2004 16:45 Go to previous messageGo to next message
Thanks for your help guys,
i really hope its something easy like that...my brother has just finished wiring it up...and im really keen to take it for a test tomorrow.. Very Happy
Chris
Hunty
Re: fwd gearbox problem - ae82 Sun, 16 May 2004 11:25 Go to previous messageGo to next message
hey im doing that exact conversion now, the only that im hung up on is which way does the driven plate, clutch plate the bit with the spings in it and the grooves for the splines of the gear box. which way does it go up?? normally they say on it but this one doesnt one side is like flat and the other side is raised where the springs are in the middle ie
v- ignore those dots, used for spacing
....._________
okay that looks shit but do you get the idea? should that raised bit sit in side the flywheel facing the engine or should it be facing the gear box??
Cheers for any help
[Updated on: Sun, 16 May 2004 11:38]
SW20R
Re: fwd gearbox problem - ae82 Sun, 16 May 2004 11:36 Go to previous message
what release bearing are you using? what flywheel?
i had this problem with my ae82 before. the clutch release bearing used was the wrong one.
There is 2 types for The 4AGE AE82-92/3
it depends on what the flywheel/clutch size is
A bleeding could also help
Previous Topic:New file repository
Next Topic:AE86 Muffler Choice (NA Blue Top)
Current Time: Sat Oct 31 21:07:14 UTC 2026
Total time taken to generate the page: 0.015212059020996 seconds
