Toymods » Tech & Conversions » turbo shaft play?
the dayo
turbo shaft play? Wed, 07 April 2004 08:46 Go to next message
i've got a T25 turbo going on my engine in a week or two, and the thing is that i don't know what condition the turbo is in, i'll have to wait till i start the engine up to see if the oil seals are broken, so i want to know what amount of shaft play the turbo should have if any, the compressor wheel wiggles a tiny bit but not much (1/2 mil at most, is this normal or should there be no shaft play at all, i've been told off a mate that this is normal? any comments would be great.
dave
Re: turbo shaft play? Wed, 07 April 2004 08:55 Go to previous messageGo to next message
turbos will always have a minescule amount of shaft play.
0.5mm - I'm guessing the turbo is used? that's acceptable, my 1jz front turbo has about that much play at the moment
the dayo
Re: turbo shaft play? Wed, 07 April 2004 09:20 Go to previous messageGo to next message
cool, so if the seals are good everything should go as planned, thnaks
CLG
Perth, Western Australia
Re: turbo shaft play? Wed, 07 April 2004 11:31 Go to previous messageGo to next message
yep, sounds OK. All good turbo shops should and usually do give a free 30 second inspection for a turbo, they will confirm it's condition generally for you.
Fattony
Re: turbo shaft play? Wed, 07 April 2004 13:50 Go to previous message
Yeah all turbos should have shaft play (just a little bit). Also you might want to check what condition the fins are in, if they are damaged on the outer, that will tell you if the shaft has to much play. Also check to see what the oil in the oil return and feed is like, remember thats wat goes through the turbo, and if it has a water feed, check that it does not have any blue shit in the fitting inside the chra, this generally means that the turbo has a knakered seal.
Previous Topic:Car drives to the left - castor?
Next Topic:Mouting 4AGE to engine Stand
Current Time: Wed Nov 18 13:13:27 UTC 2026
Total time taken to generate the page: 0.015790939331055 seconds
