Toymods » Tech & Conversions » 20v tuning
neat 20valve
20v tuning Wed, 07 April 2004 09:20 Go to next message
hi all
i am needing to know where the dots on the cam wheels are to be when No.1 cyl is at top dead center,
i took my ex, cam off and think i am out by a tooth or two as i cant get it to run smooth adjusting the dizy. need help asap
any coments ?
regards craig
the dayo
Re: 20v tuning Wed, 07 April 2004 10:46 Go to previous messageGo to next message
when i had my 20V at TDC, the points on the cam gears were both slightly facing the middle of the engine, once you've done this an easy way to see is if you take off the rocke cover and you can see if the lobes are clear of the valves
sideshow
Re: 20v tuning Wed, 07 April 2004 11:38 Go to previous message
a dot on each cam fill face upwards
they should match dots or lines on the cover around the gears
then in the middle between the 2 gears there should be a dot and a line
they will match up with eachother
one gear has dot opther has line
they should be lined up
Previous Topic:ECU for 4agte, Whats good????
Next Topic:Quick Q: What series diff in KP61 Starlet
Current Time: Wed Nov 18 04:32:39 UTC 2026
Total time taken to generate the page: 0.0044710636138916 seconds
