Toymods » General Car Talk » Rolling Diameter Q ???
manipulate
Rolling Diameter Q ??? Tue, 20 August 2002 00:09 Go to next message
Hey all
Newb Question here ...
Now obviously if u change to rims that have a bigger rolling diameter...u lose performance. But u can counter that by changing your gearbox etc to get your gearing back to normal right ??
I'm just wondering is there any advantage to doing this as opposed to leaving the rolling diameter and gearbox stock ???
Ta ppl
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon3.gif  Re: Rolling Diameter Q ??? Tue, 20 August 2002 00:20 Go to previous messageGo to next message
Rolling diameter depends on the tyres too, that's why you go to lower profile tyres if you get bigger wheels...
Try this tyre size calculator:
http://www.miata.net/garage/tirecalc.html
manipulate
Re: Rolling Diameter Q ??? Tue, 20 August 2002 00:21 Go to previous messageGo to next message
Yep i know. Ta for the link though.
Just wondering if there is any advantage over doing what i said above ??
Smiley =
Nark
Cabramatta, NSW
Re: Rolling Diameter Q ??? Tue, 20 August 2002 00:52 Go to previous messageGo to next message
Higher gears/diff ratio will give you back some of the lost torque but will also lower your top speeds through each gear.
Depends on what you want to achieve I suppose...
mr supra
Wollongong
Re: Rolling Diameter Q ??? Wed, 21 August 2002 08:46 Go to previous message
what I'd be asking is, is it worth spending all the $$$ on something that you are probably not going to notice anyway?
adding a couple of cm's to your overall tyre diameter is going to do twotenths of buggerall, at least noticably buggerall. However if you looked into getting the gerabox re-ratio'd, then took that money and did something to make it go better then everything would even itself out nicely, the car would be faster (hopefully) and you wouldn't have spent a lot of money to get no where....and here I am speaking from experience...and the brokeness that always follows
Previous Topic:Getting a Sprinter sprayed
Next Topic:Accident Who's at fault?
Current Time: Fri Nov 20 13:34:24 UTC 2026
Total time taken to generate the page: 0.0042970180511475 seconds
