Toymods » Tech & Conversions » 1FZ Questions
trd87t
1FZ Questions Thu, 08 April 2004 04:08 Go to next message
Got a general question about this engine:
What's the length of the engine from back to front. Also, what's the height of the engine, basically from the sump to the highest point.
These questions are for MS-75:
You said you mated a Supra 4spd tranny to it. Did you use one from a mk3 or mk4? The reason I ask is b/c of the bolt pattern. Or did you just make an adapter plate? Also, I noticed from your pic that you modified the intake on it. How did you do it? Just weld a piece of pipe to the other side?
Hopefully someone has the measurements. Looking to put this engine in a particular body and i'm questioning if it would fit.
Thanks peeps.
MS-75
Re: 1FZ Questions Wed, 14 April 2004 07:18 Go to previous messageGo to next message
Hi mate-With the intake, that's just a 3 inch alloy bend that is blended into the bottom corner of the plenum. It's really only temporary and will be changed to a VL/supra/skyline log style plenum with internal bellmouths soon. If you get a 100 series motor to begin with it has a better plenum setup for modifications anyway and a coil pack ignition arrangement (mine is an electronic dizzy, but that suited me as I have a crane hi-6 CD ignition system on it)
As for the trans, when I had it all rebuilt by MV autos, it turned out it was actually a cressida A340 (a few minor differences) trans, but when it was rebuilt mike put all the supra bits in it anyway. Short story is that it's a race prepped MK3 supra turbo trans. As for the bolt pattern, I made an adaptor plate to go in there. Hence, any trans you like can be fitted-trimatic, A340, powerglide, C4, any manual etc-you just have to make the plate (not too hard in the end-although you need to do some rooting about to get the starter sorted-but there are many ways to skin a cat, and it'll depend how much room you have/can make)
As for the size, I don't have it on hand but will measure tonight.
Sean
trd87t
Re: 1FZ Questions Fri, 16 April 2004 00:02 Go to previous message
Thanks for the info... I appreciate you getting the measurements for me!
Previous Topic:Help Needed - Welding
Next Topic:Corolla Fuel tank sender
Current Time: Sun Oct 18 20:05:31 UTC 2026
Total time taken to generate the page: 0.0051760673522949 seconds
