Toymods » Tech & Conversions » 5SGTE
DunkyMonkey
Brissy QLD
5SGTE Thu, 08 April 2004 11:07 Go to next message
okay looking around on the net, i found this
"get a 3sgte and put i a 5sfe crank then you have a 5sgte 2.2L turbo. its pretty big with turbo MR2s. can make up 500hp+ depending how much you want to put into it."
now what problems would i come accross if i were to buy a 3SGTE rebuild it put the 5SFE's crank in to the 3SGTE? can it be done?
[Updated on: Thu, 08 April 2004 11:07]
Re: 5SGTE Thu, 08 April 2004 11:25 Go to previous messageGo to next message
Why would you want to butcher a great engine like the 3S-GTE? The 3S-GTE is known as a square engine. Meaning that the bore and stroke is equal(86/86mm). Why would you want to screw this up with a weak 5SFE crank?
gabe
Re: 5SGTE Thu, 08 April 2004 12:01 Go to previous messageGo to next message
Cool1 wrote on Thu, 08 April 2004 19:25
I agree with this to an extent. There is more to this than first thought. More precisely, the 5s big ends are 4mm larger than the 3s. Meaning either the 5s crank needs to machined down or the 3s rods require machining. I know I would machine the crank before I would machine rods. Shorter pistons are also required due to the longer stroke.
Anyway, the 5s crank is actually forged like the 3s and is as strong, if not stronger than the 3s. It has been known to take huge horsepower and is equally as reliable.
Is it worth ruining a square engine for the sake of 200cc? Dunno.
Will the extra torque generated by the longer stroke be noticeable? Dunno.
DunkyMonkey
Brissy QLD
Re: 5SGTE Thu, 08 April 2004 15:47 Go to previous messageGo to next message
all things worth being considered, as well as would my FWD can and gear box like this much power goin thru 'em
nup_4ac
blacktown
Re: 5SGTE Thu, 08 April 2004 23:36 Go to previous messageGo to next message
cant you just wack a 3s head on the 5s block and save some stuff round? like a 7age setup thingy?
DunkyMonkey
Brissy QLD
Re: 5SGTE Fri, 09 April 2004 00:29 Go to previous messageGo to next message
you can but i believe then you have to modify some of the internals inside the engine it apparently becomes a little expensive to do it that way, at least thats the gist of things that i read.
MR. 2
Parramatta
Re: 5SGTE Fri, 09 April 2004 03:47 Go to previous messageGo to next message
why wouldnt u just go out and by a stroker kit for it ie toda have one... its all billet steel, cost 7g and u know its a good becuase its been tested and the marterial used is very strong???...
food for thought....
ae86drift
sydney.au
Re: 5SGTE Fri, 09 April 2004 03:56 Go to previous messageGo to next message
increasing displacement by increasing stroke is a common trick, but as cool1 said, 3s is a 'square' engine and a 5s crank aint got the greatest reputation
that in mind, the 5age and the 7age, being the same thing in theory (stroker kits), did work okay for most people who went through with the conversion
http://www.club4ag.com/faq%20and%20tech_pages/5A%2 0and%207A.htm
DunkyMonkey
Brissy QLD
Re: 5SGTE Fri, 09 April 2004 09:31 Go to previous messageGo to next message
thanks to everyones thoughts on this matter, i don't really have the money for this rather expensive mod, and i believe there are some more important mods b4 that one too, being 18 and all insurance company would love to see me in a turbo car right now. current list of things on the agenda are, pod filter, alarm/immobiliser system, short shifter, adjustible suspension, bonnet vents, stez, exhaust, yeah pretty much everything, spear in mind its stock, and i have had it for 7 weeks now, i really need some money to put into it!!!!
CamryMan
Re: 5SGTE Sat, 10 April 2004 12:56 Go to previous message
Do it properly and buy a 3S stroker kit.
Previous Topic:mods for 3sgte
Next Topic:new exhaust for my SV21, any ideas?
Current Time: Mon Oct 19 17:04:54 UTC 2026
Total time taken to generate the page: 0.073655128479004 seconds
