Toymods » Tech & Conversions » removing spigit bearing from 18r engine
people100
Rocklea qld
removing spigit bearing from 18r engine Thu, 08 April 2004 23:33 Go to next message
how is the best way to successfully do this
clubagreenie
1st street on the right
Re: removing spigit bearing from 18r engine Thu, 08 April 2004 23:49 Go to previous messageGo to next message
I've always used a slide hammer with a hooked end to get in behind, the bush should be shorter than the depth of it's hole, it should pull out. Just remember to work around the circumference of the bush as you pull.
wilbo666
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 09:05 Go to previous messageGo to next message
I've also heard of packing grease behind the bearing and then using a bolt (or something that just fits in the spigot hole) to force the bearing out.
suthol
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 11:45 Go to previous messageGo to next message
pack in the grease and tap a bolt though the bearing.
over the last 20 years used it more times than I care to think, too easy and no big bucks.
people100
Rocklea qld
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 11:50 Go to previous messageGo to next message
what do u mean tap it through the bearing. So it gets jammed in the hole and then just pull out or so it goes through the hole and then pull???
Mr DOHC
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 12:17 Go to previous messageGo to next message
pull your flywheel off and hammer it downwards as its laying flat
people100
Rocklea qld
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 12:18 Go to previous messageGo to next message
bearing is in the crank
Mr DOHC
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 12:24 Go to previous messageGo to next message
oh so this is the crankshaft bearing in the auto,
then u will have to hook it and pull, i.e. a slide hammer
why do u need to pull it out
people100
Rocklea qld
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 12:25 Go to previous messageGo to next message
to put a auto in my rona...need to get the manual spigit out.
Mr DOHC
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 12:32 Go to previous messageGo to next message
odd, my spigot is in my flywheel, r u sure its the spigot
people100
Rocklea qld
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 12:34 Go to previous messageGo to next message
i dont see how it can be in the flywheel. doesnt your flywheel have to slide over your crank in the centre???. I know mine does. I spent 3 hours thismorning pulling it apart.
earlyrolla
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 13:37 Go to previous messageGo to next message
The grease acts as the medium, the bolt should slide through the spigot. You use the bolt to 'hydraulic' out the spigot. The grease compresses as you hit the bolt INWARDS with a hammer and the spigot is pushed outwards. A little messy but very effect. You will need to repack the hole a few times as you go.
Even better used a stuffed input shaft from and old box instead of a bolt.
suthol
Re: removing spigit bearing from 18r engine Fri, 09 April 2004 21:40 Go to previous message
No don't jam the bolt in.
Completely fill the cavity with bearing grease or similar which doesn't compress, when the bolt is tapped in, the grease pushes the bearing out, you may need to top it up once or twice.
It's quick and does absolutely no damage.
Just use a small ball pein hammer, you don't have to bash it.
[Updated on: Fri, 09 April 2004 21:41]
Previous Topic:Polyurethane Injection
Next Topic:What is light/heavy/average weight of a 15 inch alloy?
Current Time: Mon Oct 26 07:36:51 UTC 2026
Total time taken to generate the page: 0.060182809829712 seconds
