Toymods » Tech & Conversions » Auto - Man Conversion.
Malicia
icon2.gif  Auto - Man Conversion. Mon, 20 May 2002 09:30 Go to next message
I am wanting to convert my auto RA40 to manual.
I gather i am going to need everything from the bellhousing back + fly wheel,clutch kit and so on.
what I need to know is will the parts from any celica fit or will i need to get them off another RA40?
Also this has anyone done this type of conversion b4? if so did you take it to a shop or do it yourself?
HooN
The Rainy City
Re: Auto - Man Conversion. Mon, 20 May 2002 09:51 Go to previous messageGo to next message
This was the first thing i did when i got my RA23.
You will need:
W50 gearbox, from RA40 with right extension housing for ur shifter hole.
RA40 Pedal box
Clutch Cylinder/Slave Cylinder
All Clutch lines
Thrust bearing
Thrust fork
Presure Plate
Friction Plate
Flywheel
Driveshaft
And plus the gearboot, gaiter etc....
From memory, i only spent a 100 or so on the lil parts, all 2nd hand, another 100-150 for gearbox and xmember.
I had a friend at a mechanics place put it in cos hes a rwc tester and cos he has a ratchet gun and i dont Smile
Good luck!
And dont forget to tell Vicroads or whoever that ur car is now a manual, a simple phone call should do if it was done by a mech.
PS i basically used RA40 parts to put into my RA23, so i guess theyre interchangeable. Its just the shifter location is different i think, ass RA40s have two shifter locations? i.e RA40a and 40b
[Updated on: Mon, 20 May 2002 09:54]
Jonny2TG
Tasmania
Re: Auto - Man Conversion. Mon, 20 May 2002 14:59 Go to previous messageGo to next message
Also, short out the auto shifter inhibitor switch or you won't be going anywhere.
wilbo666
Re: Auto - Man Conversion. Tue, 21 May 2002 07:34 Go to previous messageGo to next message
Anyone know how much to get it done by a mechanic??
(say 5M-E Cressida to W58??)
RA28
Re: Auto - Man Conversion. Tue, 21 May 2002 12:27 Go to previous messageGo to next message
do it yourself you lazy shit!!
The tailshafts should line up OK...My Ra28 auto tailshaft lined up ok when I used a W57 out of a RA60 (I used all the parts off a RA60 but I ended up with some dodgyness in the pedal box. find the right pedal box if you can.)
The conversion is real easy, it is the first mechanical thing I ever did and it went OK took me 2 days though.
Good luck.
wilbo666
Re: Auto - Man Conversion. Wed, 22 May 2002 00:19 Go to previous messageGo to next message
If it was soooo easy I would do it
(maybe with some help...)
But I can't just use the W57 out of an RA6X because I need an M series bell housing, so I'd need one of those as well (prbly off a MA61 supra, cheap?? lol) also a manual x-member for a cressida?? (ever seen a stock manual cressida?, so that means custom mounts....or adapt a MA61 x-member?) also the tail shaft IS the wrong length so that has to be made shorter (not a big deal really...).
And I still need the master and slave cylinders and pedals!
Don't get me wrong I would love to do it, but its a bit more work that converting a car that did come out in manual form at some stage, and cressida parts are not exactly all over the place!
faulksy
Re: Auto - Man Conversion. Wed, 22 May 2002 12:33 Go to previous messageGo to next message
It would easily cost a grand for a shop to do it for you. An expensive excercise. Gearbox and new clutch arent cheap themshelves. Best to find someone with a bit of knowledge to show you how. Not a fun job but best of luck
Malicia
Re: Auto - Man Conversion. Wed, 22 May 2002 12:43 Go to previous messageGo to next message
My friends mum own a transmition shop the quaote i got from him was not inviting so i'll do it myself
was over one and a half grand.
faulksy
Re: Auto - Man Conversion. Wed, 22 May 2002 12:59 Go to previous message
See i knew the price figure wouldn't be pretty. Could be cheaper just to buy a Celica with a manual. Depends on how attached you are to your car
Previous Topic:1j wiring GURU's needed!!!
Next Topic:Cost of conversion ....
Current Time: Fri Nov 20 14:55:51 UTC 2026
Total time taken to generate the page: 0.027333974838257 seconds
