Toymods » Tech & Conversions » white smoke
gen_gt4
white smoke Fri, 09 April 2004 09:59 Go to next message
heys all
im new to this club, and new to turbo cars.
i've just recently bought myself a 1988 st185 toyota celica gt4. i've had it for bout a month now, and haven't really trashed it. yes i've driven it hard, but neva hit redline, and always warmed up my car and turbo timed it b4 and after driving hard.
just today, my friend noticed that after starting it, white smoke began to come out from my exhaust. it wasn't alot but it was constant when i was idling. it'd stop all together after bout 5minutes of driving.
my friend says it could be my turbo, turbo oil lines, other oil lines or my cooling system. can anyone shed light on this area.
also if it indeed in my turbo or oil lines, how much will a second one cost or would it be better to recon it? also wat other turbo'w will bolt straight in?
sorry for the long post and thx for your time and help
alvin
TRD-ST162
Re: white smoke Fri, 09 April 2004 14:50 Go to previous messageGo to next message
Hey,
Sounds like a Nice car u got...
Usually with 3sfe/3sge/3sgtes the valve steam seals can go.. usually its a symptom that they will smoke at idle...
I'm not exactly sure, but thats what i've been told
These guys will be able to help u out more!!!
TRD-ST162
Re: white smoke Fri, 09 April 2004 14:51 Go to previous messageGo to next message
I heard also it could be a Head Gasket on the way if its white smoke...
These are just ideas.. it could be something completely different!!
Re: white smoke Fri, 09 April 2004 14:52 Go to previous messageGo to next message
Pull the intercooler off and have a look inside it. If its full of oil you probably have a turbo problem.
Classique71
Colac, Victoria
Re: white smoke Fri, 09 April 2004 15:11 Go to previous messageGo to next message
Aloso take it to mechanic aand get them to bubble test it for a Blown head gasket. it will soon telly uo if its that or not
RWDboy
Re: white smoke Sat, 10 April 2004 03:53 Go to previous messageGo to next message
If you take the radiator cap off when it's cold, start the engine up, and keep and eye on the coolant, won't bubbles start to come up if there is air being leaked into the cooling system (ie either leaky hoses or leaky head gasket)? Or am I off my nut.
Also, I thought oil burning smoke had a slight blue tinge to it as well?
Thirdly, does it blow white smoke in the mid arvo, or is a morning/evening thing?
[Updated on: Sat, 10 April 2004 03:58]
dingaling
tas
Re: white smoke Sat, 10 April 2004 07:27 Go to previous messageGo to next message
also remember that when you first start your car the computer will make it run richer until the engine has warmed up and starts to lean out. If the smoke is like steam then there is probably water condensation in your tailpipe evaporating.
sik sx
Sunshine Coast
Re: white smoke Sun, 11 April 2004 05:43 Go to previous messageGo to next message
could be the head gasket on its way out..when i brought my car it had a tiny bit of white smoke..3 weeks later the head gasket went and cooked my engine..u will know if u have a blown gasket Razz..other then that my knowledge of the turbo side of it is low
good luck
mk1sc
Re: white smoke Sun, 11 April 2004 05:58 Go to previous messageGo to next message
if its cold at night and u just started up the car, i find it quite normal for white smoke for first few minute
Tommo
theres a castle on my hil...
Re: white smoke Sun, 11 April 2004 07:00 Go to previous messageGo to next message
white smoke usually means water is getting into the combustion chamber which could mean head gasket. do what fwdboy said to check for bubbles. if thats a problem and you cheap, buy a bottle of radiatior stop leak, poor it in the radiator and re-tension your headgasket. this only work sometimes other wise you probably need a new gasket.
if it was an oil problem then the smoke would be blue.
celicaboy
Re: white smoke Sun, 11 April 2004 08:13 Go to previous messageGo to next message
to what tommo said.. while you have the head off get it machined flat cause the head could also be warped
does it run funny when you first start it int he morning if it has that sympton then it will definately be head gasket and/or warped head
Re: white smoke Sun, 11 April 2004 13:20 Go to previous messageGo to next message
gotta remember that the combustion products from petrol are mostly CO2 and H20, ie water Very Happy
when the air is cold, it will condense as steam...
stick your head in this 'smoke' and see if it smells like smoke Very Happy
gen_gt4
Re: white smoke Tue, 13 April 2004 21:57 Go to previous messageGo to next message
well thats the funny thing, im nto sure if its my head gasket or engine.
cuz i have a water to air cooler, i took of the cap once, and saw taht the water has a slight tinge of red..is this good? also there seems to b quite a bit of oil surrounding my intercooler inlet pipe, where it connects to the turbo.
when i boost it, the smoke that comes out is not black, nor is it blue. its grey. is this normal? should i really take it to a workshop to get it check out?
thx all
alvin
Tommo
Re: white smoke Wed, 14 April 2004 00:05 Go to previous messageGo to next message
could it be white smoke mixing with the black stuff making it grey?
grey smoke doesnt sound right.. have you done a bubble test yet?? do this before you take it to a work shop.
[Updated on: Wed, 14 April 2004 00:06]
RWDboy
Re: white smoke Wed, 14 April 2004 00:44 Go to previous messageGo to next message
Umm - in regards to sticking your head in the smoke - I would imagine it's probably not the healthiest thing to do, esp. with modern fuels and the additives - hehehe.
It's possible that if the engine has coked up a fair bit over the years that smoke could be slightly greyish or it could be rich mixture (like my car).
See if you can smell a *very* petrol-like smell near the rear of your car (although don't smell too hard) that would indicate an overly rich mixture. Oh, and yeah, do the bubble test, like, yesterday or something Smile
Zhyr
Sunshine Coast
Re: white smoke Wed, 14 April 2004 00:56 Go to previous messageGo to next message
any way to lean down an engine fairly easily?
the back of mine is always covered in soot :\
dingaling
tas
Re: white smoke Wed, 14 April 2004 11:50 Go to previous messageGo to next message
yeah my exuast smells of gas, i am sure it's running way rich.
would it be such a bad idea to advance/retard the timing a few degree's?
RWDboy
Re: white smoke Wed, 14 April 2004 14:41 Go to previous messageGo to next message
Generally it's not a timing problem. If the exhaust is clear, yet smells of petrol, then try changing the timing a bit (it may help the smell of petrol). If the exhaust is 'dirty' (dark) and smells of petrol, then you are running rich and timing has less to do with the problem.
gen_gt4
Re: white smoke Thu, 15 April 2004 15:41 Go to previous message
ok i started it up this morning, since it was cold and my friend was ova.
i left it on till the rad water started to come out, and sofar no sign of bubbles. have i done the bubble test?
also the water to air intercooler, wat colour is the liquid suppose to b?? mines a bit red/black...this aint good issit?
thx all aye
alvin
Previous Topic:surge tank install questions
Next Topic:Injector wiring problem
Current Time: Fri Oct 23 19:09:32 UTC 2026
Total time taken to generate the page: 0.0064380168914795 seconds
