Toymods » Tech & Conversions » Head Unit Pre out
SupRus
Head Unit Pre out Sat, 10 April 2004 06:05 Go to next message
Hey guys,
I have just bought a high to low level converter from Jaycar. I am trying to run an amp (which is connected to a sub) using my factory head unit (brand new factory corolla deck in a 1988 toyota Supra). I am Car audio illiterate and am wondering if someone with more knowledge than me can tell me what it is exactly that i need to do to get this up and running. In simplest terms would be appreciated. If you would rather PM or email r.moore@bigpond.net.au that would be fine.
Thx in advance,
Russ.
SupRus
Re: Head Unit Pre out Sat, 10 April 2004 08:45 Go to previous messageGo to next message
Anybody able to help?
Ideally i would like to be able to do this tmrw with guidance, else I am afraid to stuff something up.
Russ.
Re: Head Unit Pre out Sat, 10 April 2004 12:09 Go to previous messageGo to next message
Well woddaya really need to know? Just connect all the wires to the places they are marked, do a good job with all the wiring, and it should be fine. What part is confusing you the most?
SupRus
Re: Head Unit Pre out Sat, 10 April 2004 16:11 Go to previous messageGo to next message
Well,
From the converter are four speaker wires. What exactly do I wire them in to?
Callifo
Gawler, SA
Re: Head Unit Pre out Sun, 11 April 2004 01:14 Go to previous messageGo to next message
Looking at this pic
http://www1.jaycar.com.au/products_uploaded/productLarge_56.jpg
It seems to tell you exactly what to wire where on the top.
SupRus
Re: Head Unit Pre out Sun, 11 April 2004 02:45 Go to previous messageGo to next message
Yea,
The only reason I ask is because I have done as it says on the converter but it seems not to have worked. ALthough my amp light is not coming on at all, I wonder if something is wrong with it.
Russ.
FWDCelica
sydney,nsw.oz.
Re: Head Unit Pre out Sun, 11 April 2004 03:04 Go to previous messageGo to next message
Hey Russ,
Check out this site
"http://www.installdr.com/beginner.html"
Might give you a few clues !
Good Luck.
T.
SupRus
Re: Head Unit Pre out Sun, 11 April 2004 03:16 Go to previous messageGo to next message
Thx very much for that site, FWDCelica.
Unfortunately the Tech Doc relating to my problem is "not yet available". Bummer!
Still at a loss.
SupRus
Re: Head Unit Pre out Sun, 11 April 2004 04:28 Go to previous messageGo to next message
Ok guys,
I figured out the problem. Quite embarassing actually.
The remote wire for the amp was left loose in the back of the head unit area, HEHE.
So where exactly does this need to go now guys?
Sorry for wasting your time when it was something so simple.
Russ.
Callifo
Gawler, SA
Re: Head Unit Pre out Sun, 11 April 2004 04:36 Go to previous messageGo to next message
If the headunit has an amp wire, or you can use accessories off the car. You might be able to use the electric antenna wire from the headunit also but someone might want to confirm that.
sik sx
Sunshine Coast
Re: Head Unit Pre out Sun, 11 April 2004 05:10 Go to previous messageGo to next message
there should be a wire in the back of the unit that is labelled 'remote'..mine did anyways..so yeah if not i have no clue
good luck
mk1sc
Re: Head Unit Pre out Sun, 11 April 2004 06:21 Go to previous messageGo to next message
mate i've never used one of these b4 but let me c if i can help you
ok ur factory HU is old and usually dont have rca preout or remote wire. so u have to use ur speaker wires and put it thru a convertor. other side of the convertor should be rca out and now u can connect rcas to ur amp and drive the sub. some amp, or most modern amps these days allow for speaker wire input so u dont even need this convertor and just plug speaker wires straight to the amp, check ur amp first
so from the picture, the 4 wires connects to the 4 speaker wires on ur HU
SupRus
Re: Head Unit Pre out Sun, 11 April 2004 06:44 Go to previous message
Thx for all the replies and help guys,
I got the problem sorted out and ended up wiring the remote wire from the amp into the power antenna wire as suggested by Callifo. Seems to be working fine.
At least I have learnt something about car audio. Now I can drive the Supra whilst listening to some decent sounding tunes. Well, if you put aside the droning exhuast note!
Thx again,
Russ.
Previous Topic:s/c problem?
Next Topic:my pulley standard or not?
Current Time: Wed Oct 21 11:54:37 UTC 2026
Total time taken to generate the page: 0.0077159404754639 seconds
