Toymods » Tech & Conversions » Magnets on Oil Filters
jza70-mel
Perth WA
Magnets on Oil Filters Sat, 10 April 2004 12:25 Go to next message
Do any of you guys (or girls) have any first hand knowlege of sticking a big magnet on your oil filter?
There are several products now available (MRT, Beartrap) that are claiming to trap small magnetic particles from your oil as it goes through your oil filter (and presumably doesn't get filtered). The process is similar to the magnetic diff sump plug.
It sounds like a cheap mod to get that 0.001% that we all go after Laughing
Do racers for example use this device?
What about just getting a great big speaker magnet?
see:
http://www.thebeartrap.com/
http://www.filtermag.net
[Updated on: Sun, 11 April 2004 03:03]
Re: Magnets on Oil Filters Sat, 10 April 2004 13:40 Go to previous messageGo to next message
i've been using 2 hard drive magnets for a while...
it definitely does trap small metal particles in there, thats for sure..
i cut open the first filter i used the magnets with.. kinda scary too! all that metal in there... Rolling Eyes
anyways, it does work.. small magnets spread out i think would be better.. you can get good strong ones from
http://www.magneticforce.com.au/
maybe $1 each for about 8mm dia x5mm, which is big enough.. stick maybe 10 around the base and then cut open filter at next change and see what happened Wink
http://www.magneticforce.com.au/neodymium.htm
they are at Mascot too...
Cya, STewart
oh, i doubt there's any performance benefit, but it might just keep oil a bit cleaner for longer and reduce wear slightly.... suuuure.. for $10, you can't really go wrong Wink it WILL trap the ferrous particles.. not any alloy of soft metal ones tho... but most metal comes from the bores i think... could be quite good for running in methinks...
[Updated on: Sat, 10 April 2004 13:43]
Grega
melbourne.victoria.austra...
Re: Magnets on Oil Filters Sun, 11 April 2004 00:20 Go to previous messageGo to next message
um, check your sump plug! i know some yota sump plugs i've seen have had magnets actually in the middle of the plug
and yes they are quite a good idea. i like the idea of magnets on the oil filter - i reckon thats a good idea. though depending on your motor and how old it is, might be an idea to stick with oil/filter every 5000km....
FKN16V
NSW, East Coast
Re: Magnets on Oil Filters Sun, 11 April 2004 01:37 Go to previous message
[quote title=Grega wrote on Sun, 11 April 2004 10:20]um, check your sump plug! i know some yota sump plugs i've seen have had magnets actually in the middle of the plug
quote]
I know my 4age does, it also has one in the transmission drain plug, its a very good idea.
Previous Topic:2tgeu identification by blcok numbers???
Next Topic:valve timing
Current Time: Sun Oct 18 17:53:37 UTC 2026
Total time taken to generate the page: 0.07274603843689 seconds
