Toymods » Tech & Conversions » rod length info needed
ed_ma61
Lost in the K hole
icon4.gif  rod length info needed Sun, 11 April 2004 04:09 Go to next message
does anyone have the following they could possibly measure the eye-eye rod lengths for me:
-MTE
-5M
-6M or 7M
as the stroke changed across these models, either the deck height, rod length or piston compression height had to change. my money is on the rods being different.
if someone can confirm that the 7m rods are infact 3mm shorter than the 5m rods, i might just wet my pants Razz
also, does anyone have any info on nissan rods?
ed
ed_ma61
Lost in the K hole
Re: rod length info needed Sun, 11 April 2004 04:17 Go to previous messageGo to next message
note - still need 5m length data Smile
interestingly, the 7m actually has a longer rod than the 2jz:: 5.984" vs 5.590" ...
toyota:
http://www.importperformanceparts.net/imports/toyo ta-rods.html
nissan:
http://www.importperformanceparts.net/imports/niss an-rods.html
lots of other useless shit
http://users.erols.com/srweiss/tablersn.htm
[Updated on: Sun, 11 April 2004 04:29]
ed_ma61
Lost in the K hole
Re: rod length info needed Sun, 11 April 2004 08:52 Go to previous messageGo to next message
*cough*
IRA11Y
Club Member
Re: rod length info needed Sun, 11 April 2004 20:24 Go to previous messageGo to next message
Hmm making a short stroker ed ? Smile trying to get a little more RPM huh Wink
ed_ma61
Lost in the K hole
Re: rod length info needed Mon, 12 April 2004 00:14 Go to previous messageGo to next message
close...
same stroke, but found a piston with a 3mm shorter compression height. if the 5m rods are 3mm longer (as i suspect), i can plonk this all together, and gain a much more favourable rod/stroke ratio.
plus, this piston will give me about 12:1 c/r
it also means ill need to rebush the small ends down to 20mm (from 22)... ive not found a standard bush that will do this, so im hoping wilkins will be able to do it from scratch. i have to talk to him...
ed_ma61
Lost in the K hole
Re: rod length info needed Mon, 17 May 2004 00:21 Go to previous messageGo to next message
good rod tech article:
http://victorylibrary.com/mopar/rod-tech-c.htm
rod data:
http://members.aol.com/FE3N/rods.html
[Updated on: Mon, 17 May 2004 00:45]
ed_ma61
Lost in the K hole
Re: rod length info needed Mon, 17 May 2004 06:45 Go to previous messageGo to next message
http://www.genxmuscle.com/eagle/apps.html
clubagreenie
1st street on the right
Re: rod length info needed Mon, 17 May 2004 07:41 Go to previous messageGo to next message
Hey boxhead, i've ghot the 5m undeer the house remember. come over next sunday and you can check it out and remove my stitches at the same time doc.
j
ed_ma61
Lost in the K hole
Re: rod length info needed Mon, 17 May 2004 08:02 Go to previous messageGo to next message
things are getting a little more serious than 5m rods now justin Cool
some of those eagle H beam forgies are looking pretty attractive
RWDboy
Re: rod length info needed Mon, 17 May 2004 08:15 Go to previous messageGo to next message
Try Ridgecrest in Vic - they make forged H-beam conrods...I think they are slightly hefty though, and don't come in cheap.
That rod-tech article says that the lower rod/stroke ratio pistons should have a longer skirt? Yet the 5S-FE conrods are the same length as the 3S-conrods (1.6 rod/stroke for 3S, 1.45 for 5S) but the 5S-FE has a mini-skirt on compared to the 3S-GE pistons.
Does this partly explain the difference in redline between 5S-FE and 3S-GE (6300 for 5S, 7300 for 3S).
ed_ma61
Lost in the K hole
Re: rod length info needed Mon, 17 May 2004 08:24 Go to previous messageGo to next message
the longer skirt is usually related to the side loads required to be borne by the skirt due to the approach and departure angles of the rod.
perhaps the 3s has longer skirts to withstand the loads it will suffer as a consequence of its high rpm nature?
either way, i doubt it is the skirts that dictate those redline figures. more likely it is the design of valve train componentry of the 3s: the 5s's gear may not be designed to cope with high rpm use. the intake, valves and ports of the 5s may not support high rpm use either. maybe the rods and crank are of different construction?
plenty of other things to restrict rpm in that situation me thinks
RWDboy
Re: rod length info needed Mon, 17 May 2004 08:55 Go to previous messageGo to next message
Hrm...hijack... Smile
The FE head has a gear running the exhaust cam, whereas the exhaust and intake cam are both driven by belt in the GE head. The cam on the FE looks rather tame too.
Still - the approach angle of the 5S would be greater than that of the 3S so it should have the longer skirt?
The crank and rods are slightly different on the 5S, the only obvious physical difference is the larger big-end diameter for the 5S, and the longer stroke for the 5S crank. The gudgeon pins are the same size, rod length is the same. I've asked this elsewhere, but how do you test a crank's strength? I'm guessing a crank won't survive any procedure designed to test it's strength...but there's alot to it - torsional strength, maximum force on the big end journal etc etc?
Maybe I'll start a new thread Smile
Re: rod length info needed Tue, 18 May 2004 17:31 Go to previous messageGo to next message
Statement retracted! They work OK.
[Updated on: Fri, 21 May 2004 07:08]
ed_ma61
Lost in the K hole
Re: rod length info needed Tue, 18 May 2004 21:56 Go to previous messageGo to next message
gianttomato wrote on Wed, 19 May 2004 03:31
*cough* Eagle rods are shit. *cough*
ahh nutz.. Crying or Very Sad
why is nothing cheap, good?
RWDboy
Re: rod length info needed Tue, 18 May 2004 23:53 Go to previous messageGo to next message
(pimp)
Ridgecrest
(/pimp)
Probably set you back $2000-$2500 though for six conrods, but when it comes to either
a) Spending $2500 now or
b) Saving $1400 bucks now only to spend $5000 replacing the engine later.
I know which one I'd choose. It does depend how serious you want your engine to be though, and whether or not the conrod is the component under the most significant stress too.
Re: rod length info needed Wed, 19 May 2004 05:03 Go to previous message
Argo (in Newcastle) are also an excellent bit of kit. $1900 + GST for 6 though Crying or Very Sad. (4K + for Ti).
Previous Topic:1GGTE Info
Next Topic:Ta22 fan control?
Current Time: Sat Nov 21 06:24:14 UTC 2026
Total time taken to generate the page: 0.0055739879608154 seconds
