Toymods » Tech & Conversions » 18rg electronic dizzy
celicaboy
18rg electronic dizzy Mon, 12 April 2004 06:09 Go to next message
hey,
well i put my 18rg electronic dizzy in and it dont go all the way in there is bout 3mm more for it to go.. everything seems to be the same length as the mechanical one i was wondering if anybody would know why it isnt going in?
people100
Rocklea qld
Re: 18rg electronic dizzy Mon, 12 April 2004 09:48 Go to previous messageGo to next message
its not an 18rc one is it????
celicaboy
Re: 18rg electronic dizzy Mon, 12 April 2004 11:39 Go to previous messageGo to next message
the mechanical one that i have been using was from my old 18rc and worked fine
my 18rg electronic dizzy is the same where it mounts inside the engine but it just dont go all the way in
Steve M
Re: 18rg electronic dizzy Tue, 13 April 2004 00:11 Go to previous messageGo to next message
Would it happen to be getting stuck on the o-ring.
If you have a half decent o-ring, it can be really quite difficult to get it in that last little bit.
Jason
Re: 18rg electronic dizzy Tue, 13 April 2004 02:59 Go to previous messageGo to next message
i have a 18rgeu elec dizzy and a coil and ignitor from a 22re (RA60) i think does anyone know if i need anything else to hook it up cause im a bit confused with as the manual says that it may need a resistor in the wiring diagram and mine didnt come with anything???
celicaboy
Re: 18rg electronic dizzy Tue, 13 April 2004 11:08 Go to previous messageGo to next message
na it isnt getting stuck ont he seal.. i took the seal off and tried it without a seal and still did the same thing.... it stops just where the seal gets covered a lil bit before it
Jason
Re: 18rg electronic dizzy Tue, 13 April 2004 23:17 Go to previous messageGo to next message
I guess check that the teeth are meshing with the idler gear on the front of the idler shaft. If you have another dizzy just check that they roll around each other smoothley.
celicaboy
Re: 18rg electronic dizzy Wed, 14 April 2004 07:02 Go to previous messageGo to next message
yeah it is weird... the teeth seem to be going in ok but then again the part where the teeth is mounted just underntath it has been tampered with.. i filed that part round and gonna try it tonight.
celicaboy
Re: 18rg electronic dizzy Wed, 14 April 2004 08:34 Go to previous messageGo to next message
well it ried it and ti didnt work....
i have heard that the 21r and 22r ones fit i was wondering if this is true and works fine?
Mr DOHC
Re: 18rg electronic dizzy Wed, 14 April 2004 09:29 Go to previous messageGo to next message
take the old one out and sit it next to the new one and see if theres a difference in lenght
also measure the length from where the bolt goes thru to the very tip of the shaft
celicaboy
Re: 18rg electronic dizzy Wed, 14 April 2004 09:34 Go to previous messageGo to next message
done that mr dohc it is all the same.. weird
i cannot work it out
airfireman1
Perth WA
Re: 18rg electronic dizzy Thu, 15 April 2004 04:33 Go to previous messageGo to next message
sounds to mee like the dizzy is not meshing with the oil pump key way on the botom of the dizzy. if you remove the dizzy and use a long screwdriver to turn the oil pump you need the flat at the bottom of the dizzy shaft to engage into the slot of the oil pump, it may take several goes for it to lign up because as you insert the dizzy the shaft will turn as it engages the gear drive
celicaboy
Re: 18rg electronic dizzy Thu, 15 April 2004 08:29 Go to previous message
the dizzy dont run the oil pump at the bottom of it like the 18rc does Smile
Previous Topic:putting together a turbo
Next Topic:3TGTE Auto Gearbox Will it fit my Cressida ?
Current Time: Tue Nov 24 16:52:40 UTC 2026
Total time taken to generate the page: 0.10338807106018 seconds
