Toymods » Tech & Conversions » AE82 Steering Rack.
baddog
Sunshine Coast
AE82 Steering Rack. Mon, 12 April 2004 08:17 Go to next message
OK, I'm looking to remove my power steering, so two questions.
Is the non power steering rack a bolt in swap for a power steering rack in an AE82?
If not what needs to be modified to make it work?
How much heavier is non power steer compared to power steer?
Scorpion
Menai area of Sydney
Re: AE82 Steering Rack. Mon, 12 April 2004 08:53 Go to previous messageGo to next message
Yes they are interchangeable. However you may have to change your steering wheel assembly as well as they are different lengths.
I'm guessing there'd only be about 1 or 2Kg difference in weight of the racks but then you have the pump, lines and fluid to consider.
Hope this helps. Cheers.
[Updated on: Mon, 12 April 2004 08:53]
Alainve
Newcastle NSW
Re: AE82 Steering Rack. Mon, 12 April 2004 12:42 Go to previous messageGo to next message
you definateley need to change your steering column they are different lengths i converted to manual rack in my AE82 found out after it was all bolted in lucky i had a donor car
the only reason i swapped is is cos i didnt want to F**K around with hooking it all up after converting to GZE power as the pump mounts differently on the other side of the engine
baddog
Sunshine Coast
Re: AE82 Steering Rack. Tue, 13 April 2004 09:31 Go to previous message
Thanks guys, thats exactly what I wanted to know.
Previous Topic:Anyone got a pic of 4AGZ CAS internals?
Next Topic:GZE front engine mount
Current Time: Sat Oct 24 09:11:02 UTC 2026
Total time taken to generate the page: 0.03336501121521 seconds
