Classifieds » Parts Wanted » 2tg head wanted preferably with 9.8comp.
ta22celica_boy
icon5.gif  2tg head wanted preferably with 9.8comp. Tue, 20 August 2002 10:10 Go to next message
i need a good 2tg head as i have just found out tha 2tg i installed in my ta22 has practically no comprission!(pissed off)does anybody kno if it is still a yamaha head? is it possible to put a 3tgte head in? and last but not least is there anybody in brisbane that could me out, thanx
inferno
Re: 2tg head wanted preferably with 9.8comp. Tue, 27 August 2002 06:46 Go to previous messageGo to next message
ta22boy,
its the pistons that make the high compression 2tg have the high compression, the actual head flows worse than more updated heads, so you would want a yamaha head, and want to make sure it will fit you existing pistons. what kind of 2tg have you got atm?
3tgteu head: don't bother, they are supposed to flow worse, and would be a pain to convert your intake stud pattern (different to 2tg), single point spark and distributer setup for it.
ta22celica_boy
icon13.gif  Re: 2tg head wanted preferably with 9.8comp. Wed, 28 August 2002 00:07 Go to previous messageGo to next message
thanx for the info inferno,
i just found out a couple of days ago that my 2tg use to be fuel injected. but now it has the twin carby setup. so this must mean its a late 2tg model, the mechanic that is fixing my 2tg has just found a head for it. so if i wished to have higher comp. i would need nu pistons? how much would it cost to install a 3t crank, so it would stroke out to 1.8ltr. i wouldnt need to get anything machined as it is a later model, and should fit straight in? or wont it?Smile
thetoyman75
Club President
icon4.gif  Re: 2tg head wanted preferably with 9.8comp. Thu, 29 August 2002 00:35 Go to previous messageGo to next message
Before you throw money at your mechanic you need to understand a few basic principles.
Firstly 2TG head series. There are essentially 3 types of 2TG head. The first head was the 11111-88220 head and had the small valves.
The second and more common type was is head series 88222, 88260 and 88261. (There is also a unnumbered 88262 variety)
These heads all have the same larger size valves. The 88222 head was a prodominantly carby version and did not have the webbing reinforcement in the head. If your was an EFI head it has the webbbing and is most likely a 88260 or 88261 head. These are GOOD heads !! I personally only use the 88260 and 22261 heads for this very reason !
The third type of head is the low emmisons version and has an offcentre combustion chamber according to a recent post on this forum. I don't know anything else about it I'm sorry.
ALL 2TG heads were made by Yamaha !
The yamaha head myth came about as the later model ones say Yamaha and the early ones don't. Yamaha went into partnership with Toyota when Toyota made there very first Twin cam engine for the 2000 GT in the late 1960's (1966 I think, maybe 1967 ??). The engine was the 3M (Not 3M-G, the G designation was not around then !) Toyota were not experienced with twin cam setup so they had the work done by a company that was. Can't remember when Toyota started doing there own Twin cam work but I think it was around the late 80's ! (anyone ??)
Compression !
ok bad compression can be caused by 2 main areas, The valves and the Piston rings. Anything that lets pressure escape from the compustion chamber will give poor compression.
The pistons themselves determine the Compression ratio. - ALL 2TG heads have the same size combustion chamber.
There is no such thing as a 9.8:1 Compression Head ! there are 9.8:1 Compression Pistons.
If your mechanic says you need a new head ask him why ? Sounds like he is just trying to rip you off ! The 2TG head is VERY strong and not prone to warping at worst you may need new valves which would actually cost more than a second hand head Sad
Any Mechainc that says you need a new head but I have one makes me suss at best !
Hope that helps.
Call me if you want any more help or info 0416 181 284.
Regards,
Malkomv2.0
Re: 2tg head wanted preferably with 9.8comp. Mon, 02 September 2002 23:09 Go to previous message
You can buy the genuine Toyota 9.8:1 pistons, but ironically they are more expensive than fitting 1mm oversize 3t-c pistons. That of course is a new price. I happen to be selling an early 2tg that is fitted with 9.8:1 pistons. You can buy that if you want.
If you do have bent valves, fit valves from an 18rg. They are cheaper and marginally larger.
Previous Topic:AE86 Pedal Box
Next Topic:4 CHANNEL AMP WANTED
Current Time: Mon Nov 23 19:28:46 UTC 2026
Total time taken to generate the page: 0.0041401386260986 seconds
