Toymods » Tech & Conversions » Boost Problems with a 4agze
blacksta
Boost Problems with a 4agze Mon, 12 April 2004 21:49 Go to next message
I have just installed a 4agze Map sensored engine into my AE92 seca, the problem i am having is that I'm only reaching 5psi it will not boost to 8 psi. I have driven my car during the day and at night so the weather is not a issue as it doesn't boost past 5psi, The boost is consistant, i have checked the hoses to the intercooler etc the look fine, Any Ideas ???
Ps I also have some part i want to sell
4AGZE intercooler , Injectors , supercharger , the block with the head and cams etc.
i will updates post the prices later keep an eye out.
SLY16V
camden
Re: Boost Problems with a 4agze Tue, 13 April 2004 15:38 Go to previous messageGo to next message
does it still have the top mount cooler? if it is does it have a scoop or some sort of cool air hitting it cause this tends to be the problem sometimes...
cheers mate
Danish
Re: Boost Problems with a 4agze Tue, 13 April 2004 16:18 Go to previous messageGo to next message
A lot of boost gauges are not accurate.
blacksta
Re: Boost Problems with a 4agze Tue, 13 April 2004 19:34 Go to previous messageGo to next message
Yeah i have the bonnnet scoop and it is lined up properly!
blacksta
Re: Boost Problems with a 4agze Tue, 13 April 2004 19:38 Go to previous messageGo to next message
I have an auto meter gauge and its accurate. I had a 4agze in it before and that was hitting 8 psi and it was reading on the gauge. I don't think its the gauge, but thanks for the reply!
twincam_ke20
Castlemaine Vic
Re: Boost Problems with a 4agze Tue, 13 April 2004 20:54 Go to previous messageGo to next message
check for vacume leaks, thats usually the killer, mine had a few also when i did the conversion, just double, tripple check even all the pipes etc
feral4mr2
Bundaberg, Qld.
Re: Boost Problems with a 4agze Tue, 13 April 2004 22:45 Go to previous messageGo to next message
Freak belt isnt slipping?
blacksta
Re: Boost Problems with a 4agze Wed, 14 April 2004 00:05 Go to previous messageGo to next message
That could be it, i have not replaced the belt it looked in good condition...Might see how i go with that!! thanks mate
blacksta
Re: Boost Problems with a 4agze Wed, 14 April 2004 00:08 Go to previous messageGo to next message
Yeah i will double check them thanks
Adsport
Perth WA
Re: Boost Problems with a 4agze Fri, 23 April 2004 13:30 Go to previous messageGo to next message
my AW11 is an '86, when i first got it it just WOULDNT go over 5psi, thought i had a drastic problem , replaced the belt replaced the piping joins etc etc it just wouldnt boost any more. i got my hands on another charger unit and measured the pulleys on the blowers side by side, my mr2 unit was a larger pulley ... the other blower makes 8psi now i think it must have been a thing on early early GZE's to only make 5psi due to a large pulley. go to ebay and try pickup a new pulley for the blower or just an ae92 unit complete.
blacksta
Re: Boost Problems with a 4agze Sat, 24 April 2004 02:17 Go to previous messageGo to next message
Thanks for the info, i will have a look into it, i have another supercharger from a Air flow supercharge engine so i will compare it with the Map supercharger.
feral4mr2
Bundaberg, Qld.
Re: Boost Problems with a 4agze Sat, 24 April 2004 04:28 Go to previous message
yes the aw11 4agze s/c pulley is a bit larger in diameter than the later map 4agze's. but it still pushes approx 8psi from factory.
Previous Topic:4agze cam specs
Next Topic:Alternator: 14.4 Battery: 12.9 Where should I be looking? - SORTED
Current Time: Wed Oct 21 02:57:21 UTC 2026
Total time taken to generate the page: 0.0064799785614014 seconds
