Toymods » Tech & Conversions » quads on a 4age
rob-ae86
campbelltown
quads on a 4age Tue, 13 April 2004 03:50 Go to next message
ive seen this done a few time just askin what had to be done and the final cost?
ive also heard of and adaptor plate being used so you can fit the 20v ones?
any help
ae86trueno
Re: quads on a 4age Tue, 13 April 2004 06:11 Go to previous messageGo to next message
Well firstly you need an Aftermarket computer, which will cost anything upwards of $2500 realistically for a computer, install and tune, can be done cheaper though,
Then for the Quads, you can either get some dead webbers or similar, fit a TPS sensor Buy a redline manifold (I think $250),
Ask IRALLY as he is using this setup, but not the easiest to get working.
Or the 20V option, buy 20V throttle Bodies (lets say $500 if you can find some) again buy a redline Manifold get a machine shop to make up a thin plate that mounts the 20V throttles to the redline manifold, or again get a FWD manifold cheap, get a machine shop to cut the Plenum off and weld an alloy plate to the runners and mount the throttle bodies to that.(the way im running).
Another think to look out for if you run 20V throttles, a RWD top water inlet will foul on the TPS, so you will have to get either a custom one made up, or use a FWD water setup.
Ben.
AE86 Trueno 4AGE.
takai
Re: quads on a 4age Tue, 13 April 2004 10:18 Go to previous messageGo to next message
I am goign the quads from a 20v route too.
The concievable method i can see is to make a custom manifold, or use a spare FWD mani. Ill be running it from a Microtech MT8 too.
I will also be using the FWD water pump.
Anyway, thats irrelavant. But AE86trueno has posted some very good information.
Btw, got my silvertop quad intake for $260.
Ben Wilson
Re: quads on a 4age Tue, 13 April 2004 22:52 Go to previous messageGo to next message
ae86trueno wrote on Tue, 13 April 2004 16:11
Or, apprently you can invert the TB's. From what I've seen things will get pretty tight around the firewall area if you do that though....
Re: quads on a 4age Wed, 14 April 2004 05:30 Go to previous message
I'm the lazy, slow, hopeless slob that's MEANT to have a bunch of adapters cast up Evil or Very Mad Really it can't be TOO much longer now, SURELY! (I gotta finally start my car in the next week or two, get it out of the shed and on the road) Some things/people take their time a little, annoying, in'it Rolling Eyes
Previous Topic:20v efi water temp sensor
Next Topic:The way to check LSD performance
Current Time: Mon Oct 19 17:51:31 UTC 2026
Total time taken to generate the page: 0.0054290294647217 seconds
