Toymods » Tech & Conversions » 4AFC clutch info
swankiedude
Central Coast
4AFC clutch info Tue, 13 April 2004 11:36 Go to next message
Ummm, Im after the size and any other info on the clutch from a AE92 cs seca with the 4AFC carby engine.
swankiedude
Central Coast
Re: 4AFC clutch info Wed, 14 April 2004 10:31 Go to previous messageGo to next message
I need this info urgently if possible
swankiedude
Central Coast
Re: 4AFC clutch info Sat, 17 April 2004 06:56 Go to previous messageGo to next message
Some1 must know something.
HighRolla
Re: 4AFC clutch info Sat, 17 April 2004 08:24 Go to previous message
If you're buying your clutch kit from an outlet they will have a catalogue to look up. Clutch plate 212mm in diameter maybe.
When I got one for my 4age ae82 I think the same diameter was used for the ae82 4AC (200mm), however I thnk the 4AFC may have been slightly bigger(212mm). I'm pretty sure the later 4AGE had 212mm clutch plate, just not sure about 4AFC.
Don't wreck the box it comes in or handle the clutch plate with greasy fingers. The place I bought from said if you find your old one is different to this you can bring it back and swap for the same size. (As 2 were listed for the GE)
. I think thrust bearing and pressure plate had same code for most of the corollas around the same year. Check it out though!!
Ben
[Updated on: Sat, 17 April 2004 08:28]
Previous Topic:Why don't my reverse lights work in my camry
Next Topic:Something about the 3sfe
Current Time: Wed Oct 14 18:46:56 UTC 2026
Total time taken to generate the page: 0.091326951980591 seconds
