Toymods » Tech & Conversions » What is a bush in a gearbox?
SupraPete
What is a bush in a gearbox? Tue, 20 August 2002 23:28 Go to next message
What is a bush?
A mate that bought my 924T with a slooppy gearbox (could put it in 1st and move it to where 5th should be) was missing a bush. If anyone knows the 924T, how did he put it in? (trick question)
Same guy said that Supras are prone to having the same bush "go" on the gearbox, which makes it sloppy.
I want my gearbox selection to be a bit more ... defined. How hard is it to change a bush?
Can I do it?
I've been told theres a really good Toyota/Supra gearbox place around either Morebank or Milperra that will know all about my gearbox, how to put in a shortened shifter (shortened throw and shortened stick). Anyone know who this is?
raSkaS
Perth WA
Re: What is a bush in a gearbox? Wed, 21 August 2002 00:48 Go to previous messageGo to next message
i dont know that gearbox ,but id say they were taking about a bush in the shifter housing,pull all the trim off around the gearstick and have a look
Cam
Corvid
Re: What is a bush in a gearbox? Wed, 21 August 2002 04:59 Go to previous messageGo to next message
There is a plastic/poly type of bush on the bottom of the stick, when you remove the plate that holds the stick in the selector its on the base of the stick, it goes over the round knob on the end, theyre like $7 from toyota, so not sure about you application but once you put a new one in, you will think you just got your box rebuilt Smile
Nod
SupraPete
Re: What is a bush in a gearbox? Wed, 21 August 2002 05:02 Go to previous message
Great, thanks, something else to add to the list of things to do when the engine is out.
Previous Topic:4ac timing settings and a question power range.
Next Topic:Mk2 Supra - Transmissions
Current Time: Thu Nov 19 14:58:32 UTC 2026
Total time taken to generate the page: 0.0086798667907715 seconds
