Toymods » Tech & Conversions » Tacho
DunkyMonkey
Brissy QLD
Tacho Tue, 13 April 2004 15:17 Go to next message
hi everyone again, umm as everything else in my car my tacho doesn't work properly, i rather desides to work when i feels like, but never to the point where i will go to the redline. if its warm then she'll rev to 4G when she seems more like shes doin 8 ~ not the smartest thing in the world, never-the-less don't try the this at home kiddies~ neways i figure its a loose wire, ne other idea on what it is? ~if it helps its a celica ST184~ in the morning you'll be lucky if the tacho moves off 0 at idle. i dunno what wrong with it i may take it to an auto electrican this week.
TA22
icon7.gif  Re: Tacho Wed, 14 April 2004 06:37 Go to previous messageGo to next message
have u tried hitting it. cuz i got a VN Calais and sometimes the guages sit on 0 not doin anything. then i give the dash or cluster a good thump and its back to normal again
DunkyMonkey
Brissy QLD
Re: Tacho Wed, 14 April 2004 07:54 Go to previous messageGo to next message
unfortunately it always moves, however not nearly fast enough or for long enough
Re: Tacho Wed, 14 April 2004 08:38 Go to previous messageGo to next message
The Commodore problem is classic, and common to many Australian cars for many years (namely Ford and Holden!). On the Celica I'd maybe try substituting the ignitor for another one, after checking the wires/connections etc. of course!
DunkyMonkey
Brissy QLD
Re: Tacho Wed, 14 April 2004 08:59 Go to previous messageGo to next message
yeah i think i'll take it to an auto electrician and see what he says it still works i figure it must be like the wiring or somehting
DunkyMonkey
Brissy QLD
Re: Tacho Tue, 20 April 2004 05:01 Go to previous messageGo to next message
okay the car never made it the the electrican, but i know whats wrong with it, a mechanic friend told me as he had to fix one in the same model car, apparently its the lube they use in it, as it ages it turns to glue and yeah as you can imagine the needle doesn't move the way i should, with this being said to fix it you need to remove the dash and spray CFC's or something in it and it will work fine, be warned to not spray it on the white as that shows thru to display. when we fix mine up i'll let you all know what you need to spray on it as i'm not to sure right now.
pedroenglish
Re: Tacho Fri, 30 April 2004 11:28 Go to previous messageGo to next message
WD-40.
DunkyMonkey
Brissy QLD
Re: Tacho Fri, 30 April 2004 12:58 Go to previous message
yeah i'm lazy and/or have no time, i still haven't fixed it yet!!!
Previous Topic:Rubber mount on 2 peice tailshaft
Next Topic:Flywheel enhancement
Current Time: Wed Nov 18 17:12:51 UTC 2026
Total time taken to generate the page: 0.0070998668670654 seconds
