Classifieds » Miscellaneous » 2JZ-GTE engine , + JZA80 supra 6spd clutch kit
cheese124
2JZ-GTE engine , + JZA80 supra 6spd clutch kit Tue, 13 April 2004 16:23 Go to next message
got a 2jz-gte engine (68000kms)
runs, turbo good, but crankshaft/bearing problems
ideal for build up for those 400+Kw figures
selling complete
give me a offer....all offers considered
Also clutch kit consists of
TRD pressure plate
standard dual mass flywheel
heavy duty cltuch plate (worn but not slipping)
asking for $1000
based in melbourne
can call me on 0422169810
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Tue, 13 April 2004 21:53 Go to previous messageGo to next message
$500 for engine. You keep the turbos.
JZZ30MAN
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Wed, 14 April 2004 06:18 Go to previous messageGo to next message
Interested in the motor.
Is the crankshft OK or is it damaged?
Is the problem just with the bearings?
What checks have you had done to the motor?
Any compression or bleed-down tests?
Whats the history of the motor?
If you could email me direct to my address on my profile address it would be appreciated.
Evil_Foetus
Ballarat, Victoria
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Wed, 14 April 2004 07:28 Go to previous messageGo to next message
JZZ30MAN wrote on Wed, 14 April 2004 16:18
yep, what he said Very Happy
quick 6
Brissy
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Wed, 14 April 2004 09:42 Go to previous messageGo to next message
$1000 for 2j and you can keep the turbos
roland
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Sat, 17 April 2004 00:42 Go to previous messageGo to next message
Don't waste your time fellas.
As you can see a price was negotiated and agreed upon.
Following a PM and subsequent phone conversation I had no reason to doubt this.
So this morning I present with the appropriate cash only to be told that in fact it's worth 3 times that and that the engine would be fine if I just replace all the bearing so it should command a (rather generous) full price. The engine has a big end knock from the description provided which occurred after some drift action.
After a 24 hour shift and then trekking to the other side of Melbourne to receive this greeting, I am most displeased.
I would recommend not purchasing from this seller.
Evil_Foetus
Ballarat, Victoria
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Sat, 17 April 2004 07:41 Go to previous messageGo to next message
cheers for the heads up dave Very Happy
kingmick
Banned by his request
moved to tamworth
Re: 2JZ-GTE engine , + JZA80 supra 6spd clutch kit Sat, 17 April 2004 09:04 Go to previous message
if the engine has a knock you can bet you are going to have to take the crank to 10' under. and if its done the bearings why? no oil changes,detenation, surge? always be suspicious of an engine that needs bearings as the rest of the engine might need attention. cheese124 very bad form, and may i ask how you know it just needs bearings? had the sump off?our your mechanic phycic?
mick
Previous Topic:Altezza engine manuals
Next Topic:Supra Steering wheel
Current Time: Sun Nov 1 00:20:08 UTC 2026
Total time taken to generate the page: 0.026317119598389 seconds
