Toymods » General Car Talk » What kind of AMP ?
jpower
What kind of AMP ? Wed, 14 April 2004 02:02 Go to next message
im about to put a system in my car and was wondering what kind of amp i should be running ? i have a 12" mtx thunder4000 and two 4 way 200W pioneer 6x9's
i dont have an amp for them and dont know what kind to get, i dont understand all this monoblock and stuff ?
can anyone enlighten me ?
Squid
Re: What kind of AMP ? Wed, 14 April 2004 02:11 Go to previous messageGo to next message
Get rid of the 6*9's they are an in between for people who don't have subs and want everything from a tweeter to a sub in one package.
Plus the standard shelf mount 6*9's and sub in boot combo will produce nothing but crap, the sub and the 6*9's will be opposing each other, 6*9's will loose the battle and you will have no mid range. Get a pair of 6 inch splits in the front.
As for amp prolly go for a 4 channel and bridge for the sub, but talk to the dealers, they generally have a good idea of what will work best for your budget.
Lambolica
Northwestern Sydney
Re: What kind of AMP ? Wed, 14 April 2004 02:12 Go to previous messageGo to next message
There a many schools of thourght about car audio setups...
This is my recommendation for a simple install (read) good performance cheap end of the scale. Be open to others ideas as well as you'll get told alot of different ways.
The following is my recomendation:
Find a nice 4 channel amp with a good ouput. connect the 6x9's to channels 1+2 and "bridge" channels 3+4 to run the sub.
Do you have front speakers installed??
This is a good Amp for the money. No flashy lights, Names etc but good shit...
http://www1.jaycar.com.au/products_uploaded/productLarge2_52.jpg
Specs here.
http://www1.jaycar.com.au/productView.asp?ID=AA043 5&CATID=24&keywords=&SPECIAL=&form =CAT&ProdCodeOnly=&Keyword1=&Keyword2= &pageNumber=&priceMin=&priceMax=&S UBCATID=595
jpower
Re: What kind of AMP ? Wed, 14 April 2004 02:16 Go to previous messageGo to next message
yes ive contemplated the response amp, and thought about doing exactly that, using chan 1+2 and bridging the other 2. I have no room for speakers in the front of my car as it just didnt come with any (ford escort mk2 ghia Very Happy) so thats why i wanted to put it all in the back. Also the parcel tray is metal and cant be removed so i would ahve to sit the speakers above it some how as i dont want to massacre the car its too original
thanks a lot guys
Lambolica
Northwestern Sydney
Re: What kind of AMP ? Wed, 14 April 2004 02:19 Go to previous messageGo to next message
What about pods for the fron doors?? they fix to the door trim and will take a 5 inch or a 6 inch with a small depth magnet.
You'll be much happier with the results from the front split + sub setup than rear 6x9 + sub
jpower
Re: What kind of AMP ? Wed, 14 April 2004 02:21 Go to previous messageGo to next message
hmm i must look into this
whats the difference with like 4ohm and 2ohm and power outputs ??
Lambolica
Northwestern Sydney
Re: What kind of AMP ? Wed, 14 April 2004 02:31 Go to previous messageGo to next message
Basically it's the rated output for bridged mode.
4ohm is 1 channel running 1 (4 ohm) speaker
2ohm is 2 channels bridged running 1 speaker or 2 speakers wired in paraell (sp) from 1 Channel capable of running a 2ohm load
I could go into the electronic formulas that prove it but I don't know them. Razz
Callifo
Gawler, SA
Re: What kind of AMP ? Wed, 14 April 2004 04:17 Go to previous messageGo to next message
To Work out parallel: say you have 2x 4 ohm speakers, you then flip the ohm rating, so it goes to 1/4. Then add them together 1/4+1/4 = 1/2, then flip it back so it would be 2ohm.
[Updated on: Wed, 14 April 2004 04:18]
Cyber-punk
Brisbane, QLD
Re: What kind of AMP ? Thu, 15 April 2004 10:25 Go to previous messageGo to next message
or to be a real PITA its:
Rt=1\(1\R1+1\R2)
where:
Rt= total resistance
R1= first resistance
R2 = second resistance
so if you have 2 4 ohm speakers in paralell you would
1\(1\4+1\4)
= 1\(1\2)
which = 2 ohms
i find callifo's method easy if you only have a few easy resistances to work with otherwise i use the method i suggested.
funilly enough i know people who can only really do it one way or the other no matter what the problem...yet i use whichever method "seems" easiest at the time for me...
anyways i'm just talking crap
as to what amp
those jaycar responce amps are pretty cool from what i've heard about them, good bang for buck or so people say.
as to the sub and 6x9s, from what i've been told its not a very smart idea as they sound crappy together(as squid was saying)
[Updated on: Thu, 15 April 2004 10:27]
barned01
Re: What kind of AMP ? Fri, 16 April 2004 00:42 Go to previous messageGo to next message
The perfect amp for this situation would be an Audison SRx3. It has 2 stereo channels and one sub channel, all channels are 2 ohm stable. I agree with what the others are saying too, turf the 6x9's, they are a waste if you already have a sub. Get yourself a nice set of splits for the front of your car and run them off the amp.
The amp has several different configurations that can be used, the 1 or 2 best suited are
2x75wrms + 1x250wrms @4Ohms or
2x65wrms + 1x340wrms @4/2Ohms
dimmy77_03
Potts Point, Sydney
Re: What kind of AMP ? Sun, 18 April 2004 09:18 Go to previous message
[quote title=Lambolica wrote on Wed, 14 April 2004 12:12]There a many schools of thourght about car audio setups...
http://www1.jaycar.com.au/products_uploaded/productLarge2_52.jpgquote]
Apparently Jaycar have discontinued their line of Response amps...I went to buy one but the last 1 was sold 30 min earlier Evil or Very Mad ... DAMN. Just make sure when you buy your amp, look at the RMS not W (VERY IMPORTANT) Wink
Previous Topic:Melbourne Celica Cruise?
Next Topic:Are pod filters illegal?
Current Time: Sun Oct 18 11:54:33 UTC 2026
Total time taken to generate the page: 0.013895988464355 seconds
