Toymods » Tech & Conversions » Mk2 Supra - Transmissions
Mk2 Supra - Transmissions Wed, 21 August 2002 01:06 Go to next message
How hard is it to convert an auto Supra to a manual?
What parts would I need?
If I got the gearbox stuff from an RA65, could I use it all except for the bellhousing and clutch?
Or should I just hunt down a full Mk2 Supra setup?
Re: Mk2 Supra - Transmissions Wed, 21 August 2002 01:27 Go to previous messageGo to next message
Yes, if you get all the RA6x stuff (transmission, crossmember, tailshaft, clutch pedal/hydraulics) it will all bolt into a Supra. Just add the M series bellhousing, flywheel and clutch and you're away.
Note that the RA6x will have the weaker W55/57 transmission... you should try to find a W58.
Re: Mk2 Supra - Transmissions Wed, 21 August 2002 01:35 Go to previous messageGo to next message
Yeah, some of the RA65's had W58's as well apparently, so I'll have a look.
I would prefer a W58 too for the 5th gear cos I do a lot of freeway driving.
Would it be better to just get a manual one in the first place?
Re: Mk2 Supra - Transmissions Wed, 21 August 2002 02:50 Go to previous message
Get a manual because you get everything, including the W58 gearbox and the price differential is not great. Remember you will need the UZ series bellhousing and associated driveline bits.
Previous Topic:What is a bush in a gearbox?
Next Topic:T18
Current Time: Thu Nov 19 18:08:42 UTC 2026
Total time taken to generate the page: 0.00693678855896 seconds
