Toymods » Tech & Conversions » ra 23 wiring problems
Shteeve
near chris and murray vic
icon8.gif  ra 23 wiring problems Wed, 21 August 2002 03:54 Go to next message
can anybody help me please!! i have either got a major wiring or power supply problem.
the tacho never shows more than 4 grand, even when i'm throttling it and the fuel gauge and temprature gauge also only work on sorta half power... what can i do to fix this problem easily, or do i have to take it in to an auto electrician????
the wires behind the dash are an absoloute mess, the previous owner seems to have liked messing around with things he shouldnt have been
No No No
Re: ra 23 wiring problems Wed, 21 August 2002 04:08 Go to previous messageGo to next message
I've had this happen before - the problem is a dodgy earth somewhere in the dash loom, often due to corrosion. Get under there and look for the earth lead (it will be bolted to the chassis/body somewhere) and make sure it's on properly and free of rust.
Bugman
Re: ra 23 wiring problems Wed, 21 August 2002 04:17 Go to previous messageGo to next message
I also had this problem but i can and went when I went over bumps. I ended up fnding a dodgy fuse, that was making a circuit soe of the time.
First of change all of the fuses, they are quite cheap so I wouldnt even bother checking them first. just change them and be done with it, if the problem persists it is like norbie said. But I would urge you to check the fuses as they are easy to change and no body likes getting up undr the dash.
Re: ra 23 wiring problems Wed, 21 August 2002 15:00 Go to previous messageGo to next message
go nuts... rip out ALL THE WIRING AND REDO IT!!! hehehe
or not...
Grega
melbourne.victoria.austra...
Re: ra 23 wiring problems Wed, 21 August 2002 22:32 Go to previous messageGo to next message
witzl is spot on the money
1: go to wreckers, find RA23 with dash loom, remove (label stuff so you know where it goes back)
2: remove your dash
3: rewire
4: hopefully no more problems.
Re: ra 23 wiring problems Thu, 22 August 2002 00:10 Go to previous messageGo to next message
Are you kidding?? I'd rather pull my own toenails out than re-wire the dash! That's definitely a last-resort thing; exhaust all other possibilities first!
Grega
Re: ra 23 wiring problems Thu, 22 August 2002 00:57 Go to previous messageGo to next message
eeek. toenails Wink
wiring is easy in comparison, if its the same look from the same car becomes a plug n pray opportunity Wink
Shteeve
Re: ra 23 wiring problems Fri, 23 August 2002 05:13 Go to previous messageGo to next message
thanx for the ideas guys, i'll just go and see if i can find the earth......
Dylo
Re: ra 23 wiring problems Sat, 24 August 2002 14:59 Go to previous messageGo to next message
Yeah i have a prob in the dash of my RA23. Does anybody know which fuse the parker and dash lights circut runs on? mine is non existant and im thinking (hoping) its a fuse!!!
Shteeve
Re: ra 23 wiring problems Mon, 26 August 2002 02:37 Go to previous messageGo to next message
yeah i got that one night in my corolla, it should be the fuse if the dash and taillights stopped at the same time, just find the one thats broken!
when it happened to me i had to drive home without taillights on a dark country road, but i guess i was driving fast enough that no-one was going to ram into the back of me anyway Smile
[Updated on: Mon, 26 August 2002 02:47]
stradlater
Arthurs Creek, Victoria
Re: ra 23 wiring problems Mon, 26 August 2002 08:31 Go to previous messageGo to next message
I'll just put my 2c worth in, I had a similar problem, we had forgotten to put an earth in, and the dash was doing ALL sorts of wierd things, similar to what you are describing..
Search the earths I would suggest.
GIN51E
Berowra-Sydney
Re: ra 23 wiring problems Tue, 27 August 2002 07:22 Go to previous message
i think you should put new fuses in anyway as when they get old they stuff up like mine wern't blown but wouldn't alow any current to flow through then while i was playing around with them the metal end cap just fell off, also the fuse element is connected by solder so although the fuse might not be blown it may not be alowing much current through as when solder gets old its resistence tends to rise and rise due to heating and cooling of it all the time.
thats why often with old tv's when they start playing up and you take them in to get repaired all they do is resolder all the joins and that fixes them,
so yeah in short
CHANGE FUSES IF OLD
Previous Topic:Short Shifters
Next Topic:smoky 5me cold start
Current Time: Fri Nov 20 06:14:30 UTC 2026
Total time taken to generate the page: 0.0065898895263672 seconds
