Toymods » Tech & Conversions » Injector wiring problem
TA22
Injector wiring problem Wed, 14 April 2004 15:38 Go to next message
i have found that my no 2 injector is not firing as a result of a wiring problem. im just wondering if anyone knows as to why there is a #10 and #20 injector bank and why all injectors dont run together off the same pulse.
The reason being, if i cant find the prob, can i just hardwire the injector off another injector?\
this is off an early Toyota EFI system (2TGEU)
Grega
melbourne.victoria.austra...
Re: Injector wiring problem Wed, 14 April 2004 22:02 Go to previous messageGo to next message
batched injection, would have thought that 1 and 3 and 2 and 4 would have fired at the same time - normally they all share a common positive its just the ECU which grounds out the circuit to cause it to open...
so if its 2, check, that when car is running, that its got power to one of the terminals on the plug...if not, grab power from over at number 4 then try.
if its got power, then its not being grounded out by the ECU, so, drag the ground from 4 and you should be set.
(i'm thinking 4AGE here)
TA22
Re: Injector wiring problem Thu, 15 April 2004 00:39 Go to previous messageGo to next message
yeh i think 2tge and 4age are very similar setups. yeh its weird seems like that the injectors are getting a positive current through both connections. and on the 3 better injectors both are close to 12v, whereas the buggered one is only getting about 1v to it. dunno why its underpowering itself.
dunno if u can read wiring diagrams or not but if u have a look at simon's celica website http://users.chariot.net.au/~stmezz/wiring2.htm and
http://users.chariot.net.au/~stmezz/wiring3.htm
it looks like the injector is left out on its own, but then further down it links up. any idea why its been wired differently to the others?
Re: Injector wiring problem Thu, 15 April 2004 01:14 Go to previous messageGo to next message
2T-GEU's actually fire all injectors simultaneously. There is a #10 and #20 circuit but they are both joined on the PCB so they're effectvely the same circuit. If one injector is playing silly-buggers, that suggests the wiring between the ECU and the injector is a bit dodgy OR the injector itself is stuffed. Get your multimeter out and start probing!
TA22
Re: Injector wiring problem Thu, 15 April 2004 15:12 Go to previous message
so if i cut off the old 2 wires for the no2 injector and tapped off anothers it would be ok to do? can i do it to any other injector, or is it better to use the 4th one?
Previous Topic:white smoke
Next Topic:Radiator???
Current Time: Fri Oct 23 16:34:38 UTC 2026
Total time taken to generate the page: 0.0048949718475342 seconds
