Toymods » Tech & Conversions » Mounting in tank pump out of tank?
RobertoX
Mounting in tank pump out of tank? Wed, 14 April 2004 23:09 Go to next message
I got a 180sx(SR20) in tank fuel pump for free (works perfectly) so i figured i could use it in my 4ag conversion and save a few $$$ Cool
I'm just curious if this is possible? Is there some sort of pressure overflow or anything that would normally spit excess fuel straight back into the tank? I dont fancy leaving a trail of petrol behind me Confused
Any help is appreciated, thanks...
Re: Mounting in tank pump out of tank? Wed, 14 April 2004 23:27 Go to previous messageGo to next message
Why not make a swirl pot, and mount the pump inside it, kill all birds with one stone Evil or Very Mad
FKN16V
NSW, East Coast
Re: Mounting in tank pump out of tank? Thu, 15 April 2004 01:38 Go to previous messageGo to next message
I used a vn tank and pump and installed the baffles and pump into my original tank, only cost me $200 for the install.
Steve
RobertoX
Re: Mounting in tank pump out of tank? Thu, 15 April 2004 09:58 Go to previous messageGo to next message
Yeah, I have a general idea of the different things you can do, i just wanted to see if anyone had any info on this because it costs zero dollars Smile
A surge tank will still require some sort of riser which either means getting an external riser pump or fitting an internal one... Which just brings me back to square one... I dont plan to run a surge tank at this stage ( I'll just keep tank above 1/4)
Thanks for the help though guys, anyone else?
sideshow
Re: Mounting in tank pump out of tank? Thu, 15 April 2004 10:02 Go to previous messageGo to next message
personally i would not fit an intank pump outside
the filter is fixed to the bottom
how r u goin to connect a fuel hose to the base of the sr20 pump
i had one in my hands the other day
and it might be easy job but i would not trust it
the money u saved with not havin to buy a pump can be spent of mounting it inside the tank properly
for around 200 bucks u could get the tank modified
to suit the pump
i think they also have a relief valve in the base or the top
so fuel will leak
they are made to be immersed in fuel
RobertoX
Re: Mounting in tank pump out of tank? Thu, 15 April 2004 12:40 Go to previous message
filter comes off to expose a short inlet pipe that some line can be clamped too...
I think i'll probably pick up an external pump tomorrow... thanks for the help guys
Previous Topic:AE86 service book.
Next Topic:MR2 1997 Bathust Edition
Current Time: Fri Oct 23 04:55:12 UTC 2026
Total time taken to generate the page: 0.063036918640137 seconds
