Toymods » Tech & Conversions » intercooler for 4agte
faulksy
intercooler for 4agte Wed, 21 August 2002 05:39 Go to next message
the ke30 conversion is under way and was just wondering what type of intercoolers you 4ag turo guys are running. will the stock ze one be efficient enough if its front mounted?
TE72_Turbo
Re: intercooler for 4agte Wed, 21 August 2002 12:51 Go to previous messageGo to next message
unless you're running low boost (6-8psi) I think you'll find the stock GZE cooler too restrictive.
My cooler is an overkill, its 600x300x60mm.
You dont need to go this far unless you're planning on making some really serious power for a 1.6 litre. As far as factory cores go, on a budget i'd rather have a series 4 RX7 cooler than either a GZE or supra cooler. much better internal design, less flow restriction, good cooling properties.
probably the best factory core that will fit your car would be a mitsubishi Evo Lancer or VR4 Galant intercooler. bit more expensive than a series 4 one though.
Phil
Re: intercooler for 4agte Wed, 21 August 2002 14:02 Go to previous messageGo to next message
Yeah, pretty much depends how much grunt you're looking at making! The MisterBishi ones are pretty reasonable, see what kind of price you can score one for. If you've got big plans in store, then its time to fabricate one. Mines being done right now, 660x350x80 (replacing my Supra one I was using), because eventually I have big plans (which may include a 3SGTE if the poor little 4a cries enough!), so I figured theres no point stuffing around. The best factory core you'll find is Skyline GTR, but they generally cost more than getting something made anyway. Also keep an eye on the trading post, occasionally something reasonable pops up in there.
faulksy
Re: intercooler for 4agte Wed, 21 August 2002 14:14 Go to previous messageGo to next message
yeah i wa looking at running about 12-14psi out of the t3 turbo so i guess upgrading looks like a good idea. how much do hose two Bitsaremissing intercoolers sell for? i know the gtr ones are around 900-1000
Re: intercooler for 4agte Wed, 21 August 2002 14:23 Go to previous messageGo to next message
Remember to think in terms of air consumption/horsepower rather than psi. If you put an intercooler out of a honda scamp in there, you'd easily run 30 psi, and still make stuff all power...
faulksy
Re: intercooler for 4agte Wed, 21 August 2002 14:28 Go to previous messageGo to next message
i was probably aiming at 165kw and the wheels minimum.
Re: intercooler for 4agte Wed, 21 August 2002 14:33 Go to previous messageGo to next message
Well either go the misterbishi one, or if that is '165 minimum, big plans later', then do it once do it right and get one made as big as can possibly be jammed in.
faulksy
Re: intercooler for 4agte Wed, 21 August 2002 15:01 Go to previous messageGo to next message
any idea on what they cost
Re: intercooler for 4agte Thu, 22 August 2002 02:49 Go to previous messageGo to next message
The one I'm getting made is costing $800. This is using a K&J core, 80mm thick. Personally I didn't think that was too bad, about the same price as a 2nd hand GTR core, only flows even better and has the pipes/mounting points wherever you like, not wherever nissan decided they should go.
TE72_Turbo
Re: intercooler for 4agte Thu, 22 August 2002 13:16 Go to previous messageGo to next message
$800 is a really good price for a proper core that size!
like you said, why buy a GTR one when you'd get a better deal making the end tanks to suit.
Phil
Re: intercooler for 4agte Thu, 22 August 2002 14:33 Go to previous messageGo to next message
Yeah, I was pretty damned impressed too! I'll take lots of pics when I get it, and post them up for all to see, and let you know how well it works (temp + pressure drop - although with something that size I expect my poor little engine will be struggling to make pressure drop...)
faulksy
Re: intercooler for 4agte Thu, 22 August 2002 17:38 Go to previous message
seen a vr4 one in the trader for 350. might snap that one up if any good
Previous Topic:Sacrilegious, but???
Next Topic:T50 Gbox & GZE
Current Time: Fri Oct 23 16:49:49 UTC 2026
Total time taken to generate the page: 0.0054850578308105 seconds
