Toymods » Tech & Conversions » 1jz, 2jz, 7m head stud dimensions??????
MS-75
icon5.gif  1jz, 2jz, 7m head stud dimensions?????? Thu, 15 April 2004 05:34 Go to next message
Hi guys, I'm currently screwing my turbocharged 4.5L 1FZ-FE back together following some significant head work, and have been thinking that a set of head studs might be a good idea prior to stuffing the full 18-20 psi through it. Of course there are none specifically available for this motor, but I'm wondering if a set of either 1J, 2J or 7M studs might fit.
If anyone possesses these items and it's convenient, I'd appreciate the measurements (ie thread and length) of the studs. The 1F runs 14 studs, the same as the other 3 motors O believe.
Anyway, any help would be greatly appreciated.
Sean
Re: 1jz, 2jz, 7m head stud dimensions?????? Thu, 15 April 2004 05:58 Go to previous messageGo to next message
I don't have studs but I do have some head bolts which may be of help. Will dig them up later tonight and post.
Stenno might have some JZ studs.
Stenno
Re: 1jz, 2jz, 7m head stud dimensions?????? Thu, 15 April 2004 21:33 Go to previous messageGo to next message
Sean,
I'll try and get some measurements of 1 this afternoon/evening.
bbaacchhyy
Re: 1jz, 2jz, 7m head stud dimensions?????? Thu, 15 April 2004 22:07 Go to previous messageGo to next message
I have some 7M ARP studs that I could measure for you as well, and being in Adelaide, you could even come around and have a look at them if you wish Very Happy
Call me (042 111 9249) or PM me
Michael B
PS I live near Wayville showgrounds
Stenno
Re: 1jz, 2jz, 7m head stud dimensions?????? Thu, 15 April 2004 22:31 Go to previous messageGo to next message
I just remembered I'd measured 1 up a while ago and still had the picture.
http://www.turbosupras.com/images/general%20pictures/2jz%20head%20stud.jpg
MS-75
Re: 1jz, 2jz, 7m head stud dimensions?????? Mon, 19 April 2004 12:47 Go to previous messageGo to next message
F**K. They are the right length (perfect even) but too big (ie 12mm, not 10mm as required)
I'll just stick with the stock ones to start with, and if it does start blowing gaskets once 20 psi is jammed in there I can easily pull the head off and re-drill and tap the block and head to suit the new studs.
Cheers friend
Sean
(just modded the cam wheel to retard the cam timing by 3 degrees as well-should push peak torque up in the rev range by around 1000 rpm-instant 20%+ more horsepower.........and I've got a 4 day weekend coming up so she'll be running by monday...............)
bbaacchhyy
Re: 1jz, 2jz, 7m head stud dimensions?????? Thu, 22 April 2004 07:15 Go to previous message
Stenno wrote on Fri, 16 April 2004 08:31
he 7M-GTE ones taht I have are 26mm (as per the above pic), and 30mm for the threaded ends, with an overall length of 120mm.
Diameter is 12mm as well
Michael B
Previous Topic:Need Help!! Info on 200SX Fuel Pump??
Next Topic:Chain tensioner 18rgeu puzzle
Current Time: Tue Oct 13 22:05:14 UTC 2026
Total time taken to generate the page: 0.064480066299438 seconds
