Toymods » Tech & Conversions » AE71/86 clutch slave cylinder pushrod
demuire
Ipswich
AE71/86 clutch slave cylinder pushrod Thu, 15 April 2004 12:02 Go to next message
How long is this supposed to be? I've got 2 lying around, one from something I'm not sure, the other from an ST115 and both are 65mm long... How are you meant to adjust them anyway? They don't seem to offer any sort of adjustment...
pannelvan_screema
Campbelltown, NSW
Re: AE71/86 clutch slave cylinder pushrod Thu, 15 April 2004 14:15 Go to previous messageGo to next message
Not sure on the length but you adjust your clutch from the pedal box. The rod between the clutch pedal and master cylinder.
demuire
Ipswich
Re: AE71/86 clutch slave cylinder pushrod Thu, 15 April 2004 22:02 Go to previous messageGo to next message
Adjust from the pedal box? Ah... Okay. Thanks!
shinybluesteel
melbourne
Re: AE71/86 clutch slave cylinder pushrod Fri, 16 April 2004 00:48 Go to previous messageGo to next message
just make sure you have a decent torch, and unless you enjoy neck and back pain, remove the driver's seat before you adjust it, trust me on this one.
demuire
Ipswich
Re: AE71/86 clutch slave cylinder pushrod Fri, 16 April 2004 00:58 Go to previous messageGo to next message
Oh believe me I've had more than enough neck and back pain... My garage isn't even wide enough to open the doors on the car, so the doors aren't on the car Razz
FKN16V
NSW, East Coast
Re: AE71/86 clutch slave cylinder pushrod Fri, 16 April 2004 01:43 Go to previous messageGo to next message
shinybluesteel wrote on Fri, 16 April 2004 10:48
Ill second this motion, its a pain evn with the seats removed although it is easier without them.
You'll need 2 size 10 (or12 i forget) open/ring spanner's.
Steve
allencr
tallahassee FL usOFa
Re: AE71/86 clutch slave cylinder pushrod Fri, 16 April 2004 12:49 Go to previous messageGo to next message
what change are you trying to make, or what problem are you trying to correct?? pedal freeplay?
there are 2 things on the clutch MC - the pedal stop/position and then the push rod length.
demuire
Ipswich
Re: AE71/86 clutch slave cylinder pushrod Fri, 16 April 2004 12:55 Go to previous message
I haven't even felt what the pedal is like yet Razz. I'm putting my clutch slave cylinder in, and didn't have the pushrod so was wondering how long the stock one was...
I've never seen the stock rod before, as I didn't get one with my slave cylinder, and my car originally didn't come with the engine or gearbox that's in the car now! Smile
Previous Topic:W58 Woes! (Sorry!!)
Next Topic:Alloy radiators in Brisbane?
Current Time: Mon Nov 23 22:31:29 UTC 2026
Total time taken to generate the page: 0.0062439441680908 seconds
